Eutelsat Hot Bird 13G
My comparison, the signal increased slightly
Using a VU+ Duo 4K SE and a Triax 110 cm dish with a Black Ultra LNB values are between 85 and 99 % with the exception of 10727 H which comes in at only 77 %.
According to Flysat the following have moved to 13G: 10758 V, 10796 V, 10911 V, 11117 V and 11158 V. All come in at 96-97 % here. A little bit stronger than before. On the VU+ Duo2 all show 99 % but the Duo2 always tends to show higher values than the 4K SE. However reception on the 4K SE is possible at lower values than on the Duo2.
Can confirm. 10758 V and 11278 V lost 1 dB. I'm in the absolute center of the footprint in Germany.
Strange since they are stronger in the Southern part (Motala near Linköping) of Sweden. 10758 V was 92 % yesterday. Today it's 97 % (on the 4K SE).
Please wait for the next days allowing Eutelsat to align all the signals, when 13G will be full load. No reason to alarm people about decrease (or increase) signals !
Especially since all levels reported thus far mean good marginal for stable reception.
Footprints 13 F and 13 G
I have seen many of users in middle east for example Gulf Countries and Iraq and Iran have experienced a decrease in signal after the transfer of these frequencies
it look like the coverage of middle east has been reduced, and maybe the coverage map that was leaked is incorrect
or maybe things will change , lets wait and see
The signal level is a little bit lower here in the southern part of Finland as well. I was hoping it would have been a bit better after the change. Hope this will change in a few day…
It is high time for more investors to leave Eutelsat. In today's dynamic time, it is not profitable to invest in them to footprint that are characteristic of the middle of 2003-2005. In the Middle East, the signal had to be received with a 70-80 cm antenna. and in Europe with 40-45 cm
According to Flysat the following have been transferred to 13G now:
11662 V (99 %), 11 727 V (96 %), 11766 V (95% up 13 % compared to 13C), 11804 H (99 %) and 11938 H (99 %).
11766 is up almost 2 dB here.
However things might change coming days and weeks.
Most important the reception will remain stable just as expected.
Any reports from Spain and North Africa, please.
