danaddison
- 100cm Sat dish on Superior Dark Motor Metal Gear DiSEqC 1.2-1.3 USALS GotoX, connected to ground pole
- UK
Astra 28.2E
12568 H 15000
12568 H 15000
Yea S4C12783/V/7500 GigatelHD Think it’s an S4C feed for an outdoor show.
Do you know why the frequencies of other channels on the box appear to be okay in that case? I just did a clean scan on 28.2 on a blank satellite and got regular channels on their correct freqs. I’ve got the LNB setting on the box as Universal (9750-10600) which is I think the setting for a quad mini dish LNB. I don’t recall having changed anything recently. It’s a Golden V8 if that makes any difference or helps.@SkyWatcher as mikeisyou pointed out the frequencies you are posting are incorrect - check your LNB LO settings.
Looks like the same GUI as GT Media boxes, there is likely to be separate settings for each satellite but yes 9750/10600 is correct for Sky universal LNBs. Check the frequencies of channels above 11700MHz.Do you know why the frequencies of other channels on the box appear to be okay? I’ve got the LNB setting on the box as Universal (9750-10600) which is I think the setting for a quad mini dish LNB. I don’t recall having changed anything recently. It’s a Golden V8 if that makes any difference or helps.
I’m 1 MHz out on a few of those but no more than that.Looks like the same GUI as GT Media boxes, there is likely to be separate settings for each satellite but yes 9750/10600 is correct for Sky universal LNBs. Check the frequencies of channels above 11700MHz.
That's strange as there should be no reason it'd find correct frequencies for regular channels but incorrect ones for feeds.I’m 1 MHz out on a few of those but no more than that.
Yeah very weird, I’ve deleted all the transponders and will keep an eye out for any changes. I’ve not had the younger relatives round recently either who have a habit of changing settings on things.That's strange as there should be no reason it'd find correct frequencies for regular channels but incorrect ones for feeds.
Yes frequency is correctMore Spanish women’s roller hockey but can someone please check my frequency is correct.
12695/V/7199 E-268 feed 1
0200/1010/0001
Thank youYes frequency is correct![]()
