Wanted Second Hand Enigma2 Receivers
I need a few second hand E2 receivers, makes such as Edision Nino, Edision MIO, Octagon SF8008, Vu+ models, Gigablue models. Not zgemma though.
If anyone has any gathering dust that they wish to sell please let me know.
Thank You.
Manikm909
Small'ish Dish Man
Kent, UK
sorry mate - nothing here...flogged all my old boxes.
shamone
Vu + Duo, Mut@nt HD51, Icone Wegoo,
1.3M Dish, Technomate TM-2600 Super,
Inverto Black Ultra 0.2dB LNB, 53E - 30W + Fixed Zone 2 on 28E,19E,13E
N.E UK
I have a Vu Plus Zero sitting here doing nothing if thats any good to you
Sounds OK, how much are you asking for it including postage to a UK mainland address?
flexmcmurphy
One Sky dish pointing at 28.2E
England
Why don't you want any Zgemma receivers? What's wrong with them?
flexmcmurphy
England
Maybe you don't want the hassle but in case it interests you I made a ZgemmaH7S into a satip box using minisatip. I then installed a program called w_scan_cpp on to a Linux distro running on another machine and from there was able to do a blindscan using the Zgemma tuners no problem and create a mux list from that. Details are in this tvheadend thread Is it possible to update the list of MUXes from a separate file e.g: satellites.xml - Tvheadend
Flex
It is a requirement that the receivers can have a self contained and functional blind scan installed in the image if not present in the default image.
Most makes such as Edision, Gigablue, Octagon and Vu+ have this functionality.
The zgemma blind scan is not up to the standard of these other makes and has a habit of crashing the box.
Still looking for more receivers...
cokeaddict
Vu+ Ultimo4K, Uno4K SE, Uno4K, Solo4K, Zero4K, Duo2, SoloSE v1 & v2, Solo2, Ultimo, Uno, Duo, Motorised CM 1.2m dish, Hybrid Titanium Smart Lnb with CM feedhorn and a Zone2 minidish with Inverto Unicable II
53°E - 45°W
Just a note, Vu+ 4K boxes that have fbc tuners, can not blindscan with the fbc tuners (same goes for Gigablue), incase you were not aware of this.
If they have a slot for a non fbc tuner, then you can use those tuners (provided they are fitted of course), to blindscan with.
Manikm909
Small'ish Dish Man
Kent, UK
yes, ive had a couple, and they went straight back. Useless blind scanners those Zgemma boxes
