Fantastic tool Gold Master 525 combo
Mohd Sadoon
240 cm PFA - 180 cm PFA - 120 cm PFA
Coverage 14W - 125E
Oman
HDTV and HEVC DVB-S/S2/S2X+T2/C receiver for TV, smartphones and PC + DVB2ip streamer + sat finder + DVB-T2 finder + s2 spectrum analyzer + remote diagnostics
specifications:
-DVB2IP Bridge op DVB2IP Bridge options:
Open Web API...yes
Watching DVB without TV set...yes
Extension for Android Browser...yes
Application....yes
-R.A.M.F. options:
Sat Finder....yes
Spectrum....yes
DVB-T2 Finder....yes
3G/4G Finder? under development
3D R.A.M.F. LNB support....yes
Reports with signal parameters.....yes
Remote diagnostics (sending the report to the operator/installer) ....yes
Fix-it-yourself instructions....yes
-Measurements
Spectrum.....yes
RSSI.....yes
SNR.....yes
PER......yes
LM.....yes
Output voltage......yes
Signal interference.....yes
Antenna vibration.....yes
Voltage in the cable.....yes
22kHz control signal attenuate.....yes
-S.M.D.Net options:
Streaming......yes
Play content from the web link...yes
Remote control using via HDMI ...under development
One network for all devices..under development
Playing all content in the network?.under development
-Regular options:
MPEG-4....yes
HD....yes
HEVC......yes
UHD....Using streaming
DVB-S2X.......yes
DVB-T2/C..........yes
CA......yes
Wi-Fi.......Embedded, MT7601
Lan.......yes
USB...1
RS-232....On the motherboard
HDMI......yes
AV.....Jack
s/pdif......yes
ESD protection....yes
Display.....yes
Internal IR....yes
External IR.....optional
Chipset......Montage 2230M3
specifications:
Open Web API...yes
Application....yes
-R.A.M.F. options:
Sat Finder....yes
Spectrum....yes
-Measurements
Spectrum.....yes
RSSI.....yes
SNR.....yes
PER......yes
LM.....yes
-S.M.D.Net options:
Streaming......yes
-Regular options:
MPEG-4....yes
HD....yes
HEVC......yes
DVB-S2X.......yes
CA......yes
Lan.......yes
USB...1
HDMI......yes
AV.....Jack
s/pdif......yes
Display.....yes
Internal IR....yes
£25 exc. shipping from Ali Express.
Auto roll (Poop)?
Anywan gonna take a punt in this?
Mohd Sadoon
Coverage 14W - 125E
Oman
it looks like a professional satellite finder and card satellite
RECEIVER-ANALYSER-METER-FINDER (R.A.M.F.)​
its available for Android Phones , Tablet and PC at chrome extension
antenna pointing option
spectrum analyzer option
also including SAT ID function like Dr HD 1000 and promax
also including beep sound when got signals like other finders seems like Dr HD
Mohd Sadoon
Coverage 14W - 125E
Oman
Have you tried tightening the bolts?
I tried with 3D LNB its made for the RAMF it helps to set LNB skew and dish evaluation
Mohd Sadoon
Coverage 14W - 125E
Oman
Auto roll (Poop)?
its not available in Ali Express looks stock is finish
its available on ebay also
for auto roll I told support team to add in next SW
Mohd Sadoon
Coverage 14W - 125E
Oman
Its really worth very cheap tool with high performance it can do with this
I will put my experience with this tool here
Manikm909
Small'ish Dish Man
Kent, UK
well ive ordered one, and paid over the odds, on ebay
(you cant take it with you as they say...)
Good man, i'm hovering over the go get button mainly because it's not too much wad, don't really need it but interested in a couple of things on it out of curiousity.
There is no image of the rear panel on either site. Can you post one here ?
Why are all receivers so tiny these days? You plug in HDMI + LNB cables in and there's no way it'll lie flat on your stand...
In that case, I'm sure that someone could put it in a much bigger case - and then charge you twice as much! :-rofl2
Well... hit the button, risk it for a biscuit!
I don't "get it"! - (almost?) unknown brand/unit is promoted by one (rarely seen here!) forum member on the basis of lots of unproven/un-supported fantastic claimed facilities and performance, and then "everyone" seems to want to jump on the "must buy" bandwagon!
Do please remember all those previous "satellite wunderwaffen" that, over not a lot time, proved to be fuller of holes than a tonne of Swiss cheese!
TBH, I've reported this thread to the Staff and asked them to adjudicate as to what to do about it.:rolleyes:
I think the admin are already aware of the topic, no need to report it, your pal CH has posted in it above in reply 12.
CH's post 12 simply asked for an image of the rear panel - nothing else as far as I can see. And, yes, I would hope that the Staff are already aware of this thread, but not necessarily only via CH.
BTW: I think that the term "pal" is rather OTT - I know him and he's done work for me that I can't now do because of the extent of my spinal and knee damage (and a lot of fairly - and intensifying - continuous pain in both areas).:rolleyes:
We're all grown ups on here, and have our choice whether buy the receiver or not. Personally I dont see the problem...
