EBU Test Feeds
Andreasgrdx
Athens, Greece
85 cm ,100 cm ,120 cm KU 85.2E - 45.0W
Athens , Greece
EBU Last Test Transmission Migration
EU10A > EU10B MIGRATION
Eurovision Customers Test
Satellite parameters :
Eutelsat 10B ( 10.0° East)
KU-band
11200 HORIZONTAL LINEAR
TP E10B-EVS72
Mux HM6 (Huper Mux 6)
Bandwidth 72 MHz
Symbol rate 70 Ms/s
FEC 3/4
Modulation NS4 16APSK
ASI Interface bitrate 200.714 Mbps
Date 18/08/2023
Time 08:00 - 10:00 GMT
Coverage : Europe , Middle East , Northern Africa
it look uhd 4k 200bit rate?
normaly 27 bit rate
Dave5118
1.5m Gibertini with Inverto 5434 Unicable Hybrid LNB.
TBS 6903 with EBSPro
Vu+ Uno 4K SE
Edision OS Nino Pro
Starsat 2000HD Hyper
Sky Q Silver
Sky minidish with Sky Q Hybrid LNB
Nr Manchester UK
I'm assuming "Huper Mux 6" means Hypermux, so that would mean just another mux transponder.
Wouldn't thought you will see a 200 Mbps rate for UHD, as the extra bit rate would be a waste of bandwidth due to the rule of diminishing rewards etc.
The European leagues in the football will be kicking of in earnest shortly, so will just be extra capacity to take the few remaining games that were still in DVBS2/DVBSx.
ViaHussun
150 cm offset Gibertini antenna
Inverto Premium Twin LNB
TBS 5520SE TV Card
Bursa , TURKEY
KU-band
TP E10B-EVS72
Bandwidth 72 MHz
Symbol rate 70 Ms/s
FEC 3/4
Date 18/08/2023
Symbol rate 70 000 ?
Dave5118
Vu+ Uno 4K SE
Edision OS Nino Pro
Sky Q Silver
Nr Manchester UK
Yes ViaHussun, 70 Ms/s means 70 mega symbols
7mdish
Milan, Italy
70 Ms/s means that a full transponder capacity is used, 72 MHz bandwidth as mentioned.
It is not a new configuration. From 2013 until 2018 or 2019 (do not remember) they just used such config, SR was 68571.
Please note that only Novelsat receivers are able to lock this.
