Fantastic tool Gold Master 525 combo
Paolo71
Gibertini 100cm, STAB HH120, Inverto BU 0.2dB, Laminas 120, Moteck SG2100A, Inverto Premium 0.2dB.
TBS 5925, Edision OsMio 4K plus, AZbox Premium HD+, pc AMD FX8350 ram 32Gb. IQMonitor Pro, EBS Pro, Crazyscan, DvbDream, VLC and PotPlayer.
Monterotondo (Rome), Italy
Since yesterday my unit is stuck......red light and "ON" on the left, fixed. I cannot do anything, I'm trying to follow all the emergency procedures via USB and boot, but nothing. Of course I cannot see anything by HDMI, and the LAN lights behind are fixed. I don't know what happened. I'm trying to install each version, doing everything.
Have you tried changing the batteries in the remote (or checking for LED pulse with a mobile phone ?)
Paolo71
The batteries are brand new. But the problem seems to be by the receiver side. As soon as I connect the plug I have just less than 1 second for the blue light on the right then on the left red light and display "ON" fixed. The app cannot connect. It seems the unit is stuck because of a firmware or software failure. I keep on going updating different software by USB drive and pressing Menu after connecting the plug. I'm trying all the sequential operations. I hope to fix that problem. Moreover I wrote to the developers and I'm waiting for their replies.
I didn't find the solutions written above helped with a continuous loop, you appear to have a different issue. I have not accessed the receiver by app in the time I have had it working.
Try the IR suggestion anyway, see if the remote is actually functional. There have been a number of complaints wrt the GT Media combo that were down to battery issues
gdf68
1m dish Digipower SG2100A TM2600 GM twin Lnb, GT media 8uhd, vuo duo, Xtrend 8500. GM SR525HD Nvidia Shield Sport feeds
Liverpool
Anyone got RAMF apk latest .15. .14 keeps giving me unstable connection .
Manikm909
Small'ish Dish Man
Kent, UK
it seems to be a bit of a mystery the software for this box....
gdf68
Liverpool
Yeah I got the .14 ver from they thread but .15 is page not Found. Hoping someone as it dl somewhere. Changed phones
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
gdf68
Liverpool
Annoyingly still getting unstable lost connections .
Ditto , been the same with my rx from day one.
It's been put back in it's box and in storage.
gdf68
Liverpool
What are you hoping to get from a connection
What are you hoping to get from a connection ?
The RAMF app keeps losing connection currently using it to setup dish
Impulse buy but actually help me slightly tweak a better signal when I got it, but probably boxing it off too
In the market for a new sat meter decent but not break the bank £
Mohd Sadoon
240 cm PFA - 180 cm PFA - 120 cm PFA
Coverage 14W - 125E
Oman
hi dear gdf68
how you connect the STB ?
my recommendation for installation , you should use mobile hotspot you will never lose the the connection and keep small distance between your phone and STB
gdf68
Liverpool
Got it working in the end , was my router dropping 2.4g signal. Used 5g , stable.
However was an impulse / use to realign dish and not using for put in the classified if any interest. Decent Box if your into all the analysis stuff.
I've been working for a few days with the default version of Gold Master 526 HD, not with the last one announced on the Hungarian forum.
So far, I've only explored it through the streaming part on my phone. And I admit it works fine.
I'm curious whether the new RMFA version will bring improvements and news.
So far, after testing, I have noticed that some parameters, such as a low symbol rate, cannot be processed because they are not supported by the demodulator, the Montage M88CS8001-S 594 MHz.
I hope that some of the new functions in the latest version will be useful for those who work with this device, particularly antenna adjustment and signal improvement.
Here are some screenshots of the phone from Gold Master 525 HD:
e.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
'satesco', thank you for your post here and yes, the topic makes good reading on the .hu + .de forums. :-clap Hopefully soon GitHub will reveal a link for us to test. Again, thanks and hope you are well yourself. :Y
gdf68
Liverpool
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
@satesco @lovelyperson got a link to the forum
Reluctant to advise exact of other forums re: sponsorships etc so possibly enter:-
'German forum goldmaster SR525 HD'
into say Google, find the results that may apply, read the German forum thread on the Goldmaster and amongst the posts you will see the topic link to the Hungarian forum.
Very interesting project so good luck 'gdf68'. :Y
