Help Required 2.4m dish
Beli1910
Sevnica-Slovenija
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica 8290-Slovenija
Does anyone recognize this version of the antenna? I decide to buy it, but I can't guess which company the antenna is. The owner doesn't know either. The antenna is 2.4m in size.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Do not worry about the brand, the quality looks OK. I clearly see parts A and B (circled red). Look somewhere in green circle, maybe there is some kind of label. Anyway, take the antenna, install it and be happy! :) Screenshot-20231010-100009-Vibera.jpg
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
First of all, I have to arrange a transport or a van and drive 800km. I'd rather get a ChanelMaster of similar size. I'll see. But I'm still interested in who made this type of antenna.
RimaNTSS
N-E from Riga
Ask the seller to closely look for a label on the back of the dish. From a simple look, I would say, it is good quality dish (more or less same quality as CM or Prodelin). Just drive 800km, pick it up and be more than happy! :D
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
I talked to the owner. He said that the antenna, if I understood him correctly, is Nato. That it says tomway or something similar. He used the antenna to stream to intelsatellite.
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
If it is an "extraordinary" dish, and you want to use it for Ku-band, it might have an "extraordinary" f/D ratio for normal Ku-LNB-feedhorns.
A way to roughly measure and calculate dish specs would be to measure:
height of the dish
width of the dish
topstring length (top of dish to center of LNB feedhorn)
bottomstring length (bottom of dish to center of LNB feedhorn)
I can then do the calculations for you.
greetz,
A33
RimaNTSS
N-E from Riga
That is a Prodelin, either 1250 or 1251.
Satfaca
Melmac (46N, 14.5E)
Melmac
Looks exceptional find to me! Go for it!
Manikm909
Small'ish Dish Man
Kent, UK
a33
XSAT410
Rebox RE-9000
The Netherlands
I think that will be possible only after @Beli1910 gets dish at his place :) if he decides to do so at all.
If he already has it, I wouldn't be satisfied to do just 'rough' calculations! :)
I suspect, that the present owner might not want to do exact depth at the center measurements, but maybe topstring and bottomstring measures might be more easily doable for a layman.
That is what I was thinking of.
But in the meantime, the dish seems to be identified....!
Greetz,
A33
Greetz,
A33
