Astra 1N at 19.2E
11171 H
DVB-S2/8PSK
22000 3/4
test card
800
7679 7680
Good morning!
Looks like a time count... on a black background,very sober.
what' s the big expectation?
A black friday promotion ?
Transponder changes as of November 30
Beate Uhse HD TP65 → TP47
Sky Sport F1 HD TP65 → TP47
Sky Cinema Fun HD TP65 → TP47
Sky Cinema Action HD TP65 → TP47
Sky Sport Bundesliga 6 HD TP65 → TP47
Sky Sport 6 HD TP65 → TP47
Prime Video Sportsbar TP65 → TP47
Sky Sport Bundesliga 7 HD TP65 → TP47
Sky Sport 7 HD TP65 → TP47
Sky Sport Austria 5 HD TP65 → TP47
Sky Sport Austria 1 HD TP83 → TP81
Universal TV HD TP83 → TP69
Warner TV Serie HD TP83 → TP69
DAZN 1 HD TP83 → TP47
DAZN 2 HD TP83 → TP47
Sky Sport Bundesliga 4 HD TP83 → TP81
Sky Sport 4 HD TP83 → TP81
Sky Sport Austria 2 HD TP83 → TP79
source: DIGITAL FERNSEHEN Forum
that will never be FTA...
Beate Uhse would be fun...
10906 V
DVB-S2/8PSK
22000 2/3
-Antena 3
-Cuatro
--LEFT-
11259 V
DVB-S2/8PSK
22000 2/3
Comedy Central España
-LEFT-
11436 V
DVB-S2/8PSK
22000 2/3
M+ Liga de Campeones Bar
-LEFT-
10818 V
DVB-S2/8PSK
22000 2/3
Fox
Hollywood
-LEFT-
Re:Telecinco,la Sexta
again the ghosts of Astra 1,black screen,no sound when it 's Spain on Astra...
except the good old Andalucia,Galicia,Extremadura ,Aragon. Long may they live!!
12692 H
DVB-S/QPSK
22000 5/6
Mei Musi TV
-left
new
StarParadies TV osterreich MPEG-2 13015
150 151 Ger
11127 V
DVB-S2/8PSK
22000 2/3
M+ Terror MPEG-2 30853
163 98 Spa
99 Eng
Nagravision
MTV España MPEG-2 30863
168 116 Spa
Nagravision
Gol Play MPEG-2 30864
169 127 Spa
Nagravision
Be Mad MPEG-2 30865
170 130 Spa
Nagravision
10758 V
-LEFT-
Movistar+ package
10936 V
DVB-S/QPSK
22000 5/6
Mezzo Live MPEG-4/HD 30755
160 80 Fre
Nagravision
Eurosport 1 España MPEG-4/HD 30758
167 109 Eng
108 Spa
Nagravision
back on
M+ Deportes 1 MPEG-4/HD 30760
161 86 Spa
87 qaa
Nagravision
back on
A little extra information.
On November 14, the channels marked with the dot (example WarnetTV./La Sexta HD.) stopped broadcasting at 10:00 Madrid time.
The channels of these SD versions were also modified and now the image is taken from the HD channel rescaled to SD, if as it sounds, lowering the quality, they sent the installers an informative note of the change, to the subscribers nothing at all, the There are multiple complaints and the response from Movistar+ is... due to space problems on the satellite, those channels are removed in HD version, continuing to broadcast in SD.
Surely to avoid complaints, the SD channel takes the image from the HD channel, but some will think that they lowered the quality of the HD channel without really knowing the move.
The HD channels that were "unsubscribed" are automatically being recycled for HD soccer.
The changes continue.... In 10936 V DVB-S/QPSK 22000 5/6 Today it is with these parameters, but on the 27th the channels appeared as data, one of the search devices shows DVB-S2/8PSK and I could see everything fine, but on another device that does not support channel multistreaming, I could only see one of the channels, from some comments it seems that they carried out tests in multistreaming, I did not think about it and do not look at these options when searching for channels.
As I said, today 28 are now normal DVB-S QPSK and you can see all the channels with the corresponding Movistar+ seca/nagra subscription on the normal equipment, The receiver that supports streaming insists on saying that they are in DVB-S2/8PSK when performing the blind channel search, if I manually force the search in DVB-S/QPSK, if it finds them that way.
The La Resistencia channel has already appeared as TEST R for a few minutes.
Un poco de informacion extra.
El dia 14 de Noviembre, los canales marcados con el punto (ejemplo WarnetTV./La Sexta HD.) dejaron de emitir a las 10:00 Hora de Madrid.
Los canales de estas versiones SD, tambien fueron modificados y ahora la imagen la toman del canal HD reescalado a SD, si como suena, bajando la calidad, a los instaladores les mandaron una nota informativa del cambio, a los abonados nada de nada, las quejas son multiples y la respuesta por parte de Movistar+ es... por problemas de espacio en el satelite se quitan esos canales en version HD, continuando su emision en SD.
Seguramente para evitar quejas, el canal SD toma la imagen del canal HD, mas de alguno pensara que bajaron la calidad del canal HD sin saber la jugada realmente.
Los canales HD que dieron de "baja" automaticamente los estan reciclando para futbol en HD.
Continuan los cambios ....
En el 10936 V DVB-S/QPSK 22000 5/6
Hoy si esta con estos parametros, pero el dia 27 los canales aparecian como datos, uno de los equipos de busqueda muestra DVB-S2/8PSK y podia ver todo bien, pero en otro equipo que no admite multistreaming de canales, solo podia ver uno de los canales, por algun comentario parece que realizaron pruebas en multistreaming, no lo pense y no mire estas opciones al realizar las busqueda de canales.
Como digo hoy 28 ya estan normales DVB-S QPSK y se ven todos los canales con el correspondiente abono seca/nagra de Movistar+ en el equipo normal, el receptor que admite streaming se empeña en decir que estan en DVB-S2/8PSK al realizar la busqueda ciega de canales, si fuerzo manualmente la busqueda en DVB-S/QPSK, si los encuentra asi.
Ya aparece el canal La Resistencia como TEST R desde hace unos minutos.
and what is this "la resistencia" channel?
A channel of interviews with "important" people in their world.
Un canal de entrevistas a personajes "importantes" en su mundo.
End TP32, 11686 V 22000 5/6 DVB-S QPSK
There are already unnamed channels, currently active, but they will soon be deleted.
Today the changes of the 28th end, it is now with all the channels and some remains finished in . (.) that will surely be deleted in a few days.
Add new channel TP 64, 10936 V 22000 5/6 DVB-S QPSK
As I say, it is an interview program with "important" people in their world, which has been around for a few years.
If anyone knows Andreu Buenafuente, then similar and then "applying his style" of presenter David Broncano.
These days I saw it more than in the last year, it is broadcast with the public, being able to know that they changed the scene due to the Covid-19 pandemic and having to keep their distance due to security measures, it is broadcast from the Teatro Príncipe de Gran Vía (Madrid -Spain) with 600 people in attendance now.
Como digo, es un programa de entrevistas a personajes "importantes" en su mundo, hace unos años que esta.
Si alguno conoce a Andreu Buenafuente, pues similar y luego "aplicando su estilo" del presentador David Broncano.
Estos días lo vi mas que en el ultimo año, se emite con publico, pudiendo saber que cambiaron de escenario por la pandemia Covid-19 y tener que guardar las distancias por medidas de seguridad, se emite desde el Teatro Príncipe de Gran Vía (Madrid-España) con 600 personas de publico ahora.
Photos can be enlarged...Las fotos se pueden ampliar.
