Anteena dvb t2
Any know indoor antenna dvt2 alzo lut door to weak signal ? What best range to get ?
EnoSat
enosat.euweb.cz
Slovakia
Use an external antenna
Fisty McB
See my signature...
County Tyrone, N. Ireland
If you're looking for terrestrial DVB-T(2) reception and indoors in a room is too weak, the only practical option is to either go outdoors or, if favourable & desired, putting an antenna in the loft/attic.
I'm relatively lucky in that I can pick up DTT from a transmitter more than 70km away on my bedroom TV with a simple unamplified indoor aerial, but that's thanks to having favourable conditions (upstairs room, home lies quite high to surrounding near terrain and that the path from transmitter to receiver is almost line-of-sight).
In my experience, indoor amplified antennas are nearly always a waste of electric & money - there are some very occasional examples where they can help but more often than not they do no better than a reasonably well designed indoor aerial that makes the best of its inherent limitations. And where an indoor amplified antenna has been shown to work when unamplified aerials don't, they always are just about over the signal-to-noise threshold of reception and suffer easily from impulse noise, giving a "brittle" signal.
The Televes DAT BOSS antennas that rolfw linked to makes the best use of electrical amplification by not only integrating the amp within the active receiving element of the antenna (reducing losses & mismatches) but also putting it on an antenna that's designed to be put up high outdoors which is what really needs to be done before any "suck it & see" amplification should be done.
I must say though that in my experience, with the general ease of receiving out-of-area TV these days via satellite & internet, as well as DVB-T(2) allowing frequencies to be reused at closer distances than what was needed in the days of analogue broadcasting and thus blocking more distant signals from being received either often or occasionally, the general hobby of VHF & UHF TV DXing is largely gone now except for a few hardy souls that are still going.
LeBelge
2x Triax TD 110, 2x Edision OS Mio 4K (plus), Edision OS Mini 4K, Edision OS Nino Pro
Belguim
Any one knows indoor antenna dvb-t2 also out door for weak signal ?
I do, here are the mines
for reflected signal
amplified signal
Spc..
TeVii S2 Tuners, 138cm Gibertini + 100cm backup dish
Slovenia
I am using diamond antenna that my father bought 30 years ago, range is 25-1300MHz.
I get all frequencies from FM radio, dab, dvb-t, t2, police, fire brigade, you name it.
This is external only antenna.
Model is Super Discone Antenna D130 original Made in JAPAN:
Above 70dB for FM:
DVB-T (100%):Discone-DVBT.png
DAB+ transmitter 189km away (Austria MUX) 20 dB:
Fisty McB
See my signature...
Above 70dB for FM:
Discones are good for wideband reception over a very large frequency range, but their gain is very low (something like an average of 0 dbi). If indoor DVB-T reception isn't possible in a given location, I'd doubt a discone (even one that covers the required frequencies) even mounted outdoors will be of much practical use. Fine where you could otherwise pick up many strong signals with a piece of wire, but that's why they're often employed for use where frequency coverage is more important than raw gain.
Also discone antennas are vertically polarised - I don't know the details of the DVB-T transmissions in Solly's location of Tel Aviv, but if all the wanted transmissions horizontally polarised then a discone won't be much good for this use.
Spc..
Slovenia
My model is omni, vertical+horizontal.
i added new images on my original post.
for DAB+ and DVB-T iam using simple dvb realtek usb dongle for 12€.
for FM, SONY ST-D777ES high end tuner.
I use horizontaly dvbt 26 dvbt and dvbt2 ch 28 both octagon not found signal
any signal on octagun sf 8008
i use open atv no signal
