Arabsat BADR-8
Ivan Semov
Ku-Band 2x205cmAl Parabola
C-Band 2x305cm MZT Parabola
Octagon SF8008
Veliko Tarnovo,Bulgaria
before from these frequencies Badr6 MENA,Badr5 MENA, there was no signal in Bulgaria.
I confirm that the frequencies I described above are already being broadcast by the new Badr8 satellite
12456 H 27500 Oman TV 66% SQ from Badr-8 @ 26°E
100cm Gibertini + Primo S2
Signal now reduced to 33% SQ
suedschwede
2.7m Laminas+Polarmount+JPC-Posi+SF8008
DE
Signal now in Central Germany
Current status here Badr 4-8, 2.7m + SF8008, 29.11.23 11:30 Central Germany
10970 V 9.5db
11010 V 9.8db
11230 H 5.0db
11270 V 6.0db
11473 V 6.8db
11747 V 9.2db
11785 V 5.0db
11804 H 0.0db
11843 H 6.0db
11862 V 4.8db
11919 H 13.5db
11938 H 14.2db
11958 H 12.8db
11977 V 13.5db
11996 H 15.2db
12054 V 15.0db
12073 H 12.8db
12092 V 12.5db
12111 H 11.5db
12130 V 13.2db
12149 H 12.8db
12169 V 13.0db
12182 H 8.8db
12226 H 15.2db
12245 V 12.2db
12284 V 6.0db
12303 H 7.2db
12360 V 4.2db
12380 H 8.5db
12418 H 8.8db
12437 V 9.0db
12456 H 7.0db
12523 H 13.5db
12523 V 13.0db
12563 V 14.5db
12643 H 13.5db
12683 V 13.0db
12731 H 15.5db
Satfaca
Melmac (46N, 14.5E)
Melmac
the problem is not so much DVB-S2X as the fact that it Stream Type is Packetized
Well, you first need to get a lock if you want to establish what kind of stream there is so ... there is a big problem if you don't have a DVB-SX2 capable gear. :)
satelliclub
Eutelsat 5 West B + Eutelsat 9B
Tunisia
Wath a 12731 H ?
I not have a signal to 12731 H 27500 or 30000 !
Satfaca
Melmac (46N, 14.5E)
Melmac
Yep, that is a constant Al Sharqiya feed here.
Satfaca
Melmac (46N, 14.5E)
Melmac
Major improvement in central Europe, now only Central Asia beam and Es'hailsat out of reach.
Vertical:
Horizontal:
TM5402HD M3 + 100cm Gibertini 26E
29th Nov 2023 update S/R 27500 except where stated
Badr update in dB
11919 H = 9.2 moved from Badr-5 Asharq Discovery TV now on Badr-8
11938 H = 9.9
11958 H = 10.9
11977 V = 11.7
11996 H = 11.7
12054 V = 11.3
12073 H = 10.1
12092 V = 9.5
12111 H = 8.1
12130 V = 9.4
12149 H = 10.7
12169 V = 9.5
12182 H =8.4 (16200)
12226 H = 10.1
12245 V = 10.5
12523 H = 10.1
12523 V = 9.9
12563 V = 12.4
12643 H =10.5
12683 V =10.1
12706 H =11.3 (2220)
12730 H =12.4 (3330)
'ere are my scan results below for the satellite cluster centred around 26.0E.
The dish was peaked on 12456H, SR27500, whatever satellite that is on, thought to be BadMan-8 ?
The dB figures are reasonably accurate from the tabulated list.
However, some of them increase marginally by up to 0.4dB when the Signal Analyser tab is used for a more in depth dynamic view of a specific frequency.
Surrey, UK.
Beli1910
Sevnica-Slovenija
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica 8290-Slovenija
The reception situation in Central Europe has visibly improved. I did a quick scan and I have reception of 575 channels on gibertini 150. If it stays like this, it will be great. I have to check in more detail what I'm monitoring, because I don't have time to check at the moment because of small children.
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Moram pobrskati po arhivu starih slik, pa se mi zdi, da imam sedaj na tej frekvenci močnejši signal med 3 in 4 db. Prej sem imel občasno sprejem ob ugodnih vremenskih razmerah.
I have to look through the archive of old pictures, but it seems to me that I now have a stronger signal between 3 and 4 db on this frequency. Before, I had occasional reception during favorable weather conditions.
Update
Edision Primo S2 Badr update
======56% SQ =11919 H = 9.2 moved from Badr-5 Asharq Discovery TV now on Badr-8
======64% SQ =11938 V = 9.9
======69% = 11958 H = 10.9
======77% = 11977 V = 11.7
======84% = 11996 H = 11.7
======77% = 12054 V = 11.3
======59% = 12073 H = 10.1
======56% = 12092 V = 9.5
======56% = 12111 H = 8.1
======52% = 12130 V = 9.4
======69% = 12149 H = 10.7
======56% = 12169 V = 9.5
======40% = 12182 H =8.4 (16200)
======56% = 12226 H = 10.1
======77% = 12245 V = 10.5
======74% = 12523 H = 10.1
======64% = 12523 V = 9.9
======90% = 12563 V = 12.4
======69% = 12643 H =10.5
======66% = 12683 V =10.1
======??====12706 H =11.3 (2220) No signal now
======84% = 12730 H =12.4 (3330)
satelliclub
Tunisia
We note that the current frequency of the Yemeni package on Badr 4 is 12182, horizontal 16200
It will be adjusted to 12188 horizontal 27500 when moved to Badr8
danny10
Amiko Alien 2,E - 85,Famaval 110 ,IBU twin
Czech republik
11919 H move to EMENA beam..
4Himdj
1.2 Laminas Dish
Rome
I couldn't get ssc sport channels before switching to badr8 in Rome with a 120cm dish. Around 9,5 db now pretty good
it is a pity I still can't get central asia beam
danny10
Czech republik
With a small dish on a CA beam in our latitudes, forget it..
BADR 8 in my area with 1.50m. :-ohmy
I hope it won't restrict the coverage area later, as happened with other satellites after they became operational.
