- Elite 2.2 PF with Multi lnb changer - CM1.2 - Gibertini 1.25.
Ku - Ka - Ext Ku - C & Ext C. X.
PC cards 6983,6903, main receiver GTX Combo. Ericsson RX8200.
Promax HDRanger+ & HDRanger2 Analysers.
- North Nottinghamshire. UK.
@John
Thank you, I will give it a "whirl" tomorrow.
I have a couple of options for the LNB(F) and think I know where the offending tower is.
The dish is currently aimed at 46.0E so 60 degrees either side of that should be OK.
A fair chunk of that 120 degree field of view is blocked by buildings and trees, the mobile pallet dish only has 57E to 7W arc at its current location.
One comment re the video:
On the Promax I see you have set the span range on the Promax to full, I assume that is to show the level of 5G swamping up the frequency range all the way to 4200 MHz?
@John
On the Promax I see you have set the span range on the Promax to full, I assume that is to show the level of 5G swamping up the frequency range all the way to 4200 MHz? <<
Yep correct , once i get Christmas out of the way i might , and it is might, start thinking about getting a decent External 5G 3.9-4.2 filter and couple it to a new 5G Norsat lnb ??? who knows
