BarryC
- Dec 19, 2023
- Age
- 44
- Freesat
- Connaught
I am experiencing poor reception for channels on 11306 H and V which mostly comprises of the full range of Channel 5 and Great TV! channels.
On a clear sunny day the C5 channels will stutter a lot and the Great! channels will most likely go to no signal. In this situation signal strength is about 90% and quality will be erratic ranging from 0-40%.
However, on a bad weather day with cloud and heavy rain, the signal on these channels actually improves with the channels becoming stable and watchable with signal quality reaching 50-60%.
All my other UK spot beam channels are being received at 90% strength, 100% quality without any issues.
I've had the dish moved, the alignment professionally checked twice, LNB replaced and a new cable run but the issue remains. The last guy said external interference was to blame and nothing more could be done. I don't have a DECT phone and my router is the other side of the house. Also, I have a very limited area to place the dish so moving it again isn't an option.
If anyone could suggest any further solutions or options I could try I'd much appreciate it. Thanks for reading!
