Advice Needed Can a PC7 Fransat card be activated in oscam?
sophie101
* Currently
1 x off set 60cm for 28.2e
1 x 60cm for 5w + 13e + 19.2e
Quad LNBs on each sent to different receivers in different flats.
belgium
> oscam+ultracam 11.272-emu-r798
Thanks. Googling for this, or even oscam ultracam 11272 does not give any results on Google. How did you find this?
marcouk
Vu+ Uno 4K SE, 1.2M Laminas motorised dish. Primesat 1.3 m dish
Hull UK
I get it via the update panel on Openpli 8.3.
you can download cams channel lists etc all at the touch of a button.
there are loads of different oscam versions on there (most had the same results what you have now regarding fransat)
then I tried oscam+ultracam (after deleting all other traces of the other oscam versions) and it worked fine.
sophie101
* Currently
belgium
I already had 11718 installed so tried with this because google won't find 1.272-emu-r798
I added the Fransat details backs but always get :
READER DEVICE ERROR
(no entitlements)
marcouk
Hull UK
sophie101
* Currently
belgium
sophie101
* Currently
belgium
I think I am going around in circles here.
1) I don't know which way around I have to insert the card into the reader. Edision, as expected, does not provide any informaiton on this even if they made the card reader....
2) It is likely that any configuration I add into the oscam.* files won't work, because there are no instructions for oscam. Nobody actually seems to have a clear idea of the file structure and what is required and why. It's all a stab in the dark.
3) That a specific version of oscam is required for Fransat makes me think that there is a QA problem, because nobody can identify why a specific version + revision works, and another does not.
4) Configuration files are distributed 755! See point 3. Also, the files in /etc/tuxbox/config ought to be sym linked to the currently used oscam binary. This ought to be managed by some sort of script, but it is not.
The only real option is to identify what makes oscam work with Fransat, build this ourselves for ARM, and document this properly.
However, for our sanity it is on github. I am off over there.
Their offical site is : OSCam
The actual manual is here: OSCam/en – Streamboard Wiki
sophie101
* Currently
belgium
Does anybody know what programme name oscam uses for messages? I want to send it to syslog. Perhaps I can get some logging going.
Syslog: add to the [global] section in oscam.conf:
[global]
logfile                       = syslog
Now, I have message in /var/log/messages. Phew! What a massive relief:
Dec 24 18:23:37 osmio4kplus daemon.info oscam[1133]: 51DE830B r   (reader) FRANSAT [internal] Error activating card.
Dec 24 18:23:37 osmio4kplus daemon.info oscam[1133]: 51DE830B r   (reader) FRANSAT [internal] THIS WAS A FAILED START ATTEMPT No 1 out of max allotted of 1
Dec 24 18:23:37 osmio4kplus daemon.info oscam[1133]: 51DE830B r   (reader) FRANSAT [internal] card initializing error
Dec 24 18:23:38 osmio4kplus daemon.info oscam[1133]: 00000000 s     (main) init for all local cards done
Dec 24 18:23:38 osmio4kplus daemon.info oscam[1133]: 7CE9F18B c   (client) plain dvbapi-client granted (anonymous, au=off)
Dec 24 18:23:38 osmio4kplus daemon.info oscam[1133]: 7CE9F18B c   (dvbapi) dvbapi channelcache loaded from /etc/tuxbox/config/oscam.ccache
Dec 24 18:23:38 osmio4kplus daemon.info oscam[1133]: 7CE9F18B c   (dvbapi) Detected /dev/dvb/adapter0/demux0 Api: 0, userconfig boxtype: 0 maximum number of filters is 64 (oscam limit is 64)
Dec 24 18:23:38 osmio4kplus daemon.info oscam[1133]: 7CE9F18B c   (dvbapi) Detected /dev/dvb/adapter0/ca0 device, total available descramblers: 96
^C
marcouk
Hull UK
this is exactly what I had at first. so it looks like the settings are all ok and it just a matter of trail and error to find the right version of oscamn.
as you said in a earlier post there is little/no official support for oscam nowadays (10 years or more) the only help you can get is via forums such as these.
sophie101
* Currently
belgium
sophie101
* Currently
belgium
By the way, oscam does produce better logs. I just have to find out how this is being run, because the /etc/init.d/softcam.* are not being called at boot, but oscam is running.
Logging:
-I, --syslog-ident <ident> | Set syslog ident. Default: oscam
-S, --show-sensitive | Do not filter sensitive info (card serials, boxids)
. from the logs.
-d, --debug <level> | Set debug level mask used for logging:
. 0 - No extra debugging (default).
. 1 - Detailed error messages.
. 2 - ATR parsing info, ECM, EMM and CW dumps.
. 4 - Traffic from/to the reader.
. 8 - Traffic from/to the clients.
. 16 - Traffic to the reader-device on IFD layer.
. 32 - Traffic to the reader-device on I/O layer.
. 64 - EMM logging.
. 128 - DVBAPI logging.
. 256 - Loadbalancer logging.
. 512 - CACHEEX logging.
. 1024 - Client ECM logging.
. 2048 - CSP logging.
. 4096 - CWC logging.
. 65535 - Debug all.
marcouk
Hull UK
Logging:
. from the logs.
. 64 - EMM logging.
I understand. it can be really annoying if the firmware is not to your taste/needs.
you can of coarse always go back to what you have now if you don't like open pli as it will cost you nothing but a little time.
Mark
sophie101
* Currently
belgium
Oh thank god for logging :)
I deleted all the reader lines in the oscam.server file, and added one definition for FRANSAT. ( which forum rules disallow me from posting on this thread ).
I killed the running oscam processes, and ran this:
# /usr/softcams/oscam-latest --config-dir /etc/tuxbox/config/ --daemon -S -d4 -restart 2 --utf8 2
The -S -d4 is for the extra debug information.
/etc/init.d/softcam.oscam-latest is where this should be called from, but from some reason Enigma2 is calling it from somewhere weird. I think I will have to stop it from the openvix TV GUI, and and use update-rc.d to get it to run from init.d, which is a far better place to do it anyway.
FRANCE 2 appeared as soon as I had inserted the card the right way up...
# tail -f /var/log/messages
Dec 24 19:26:14 osmio4kplus daemon.info oscam[3969]: 654CB671 c   (dvbapi) Demuxer 0 no enabled matching ecmpids -> decoding is waiting for matching readers!
Dec 24 19:26:15 osmio4kplus daemon.info oscam[3969]: 1927B926 r   (reader) FRANSAT [internal] Card successfully activated
Dec 24 19:26:16 osmio4kplus daemon.info oscam[3969]: 1927B926 r   (reader) FRANSAT [internal] write to cardreader
Dec 24 19:26:16 osmio4kplus daemon.info oscam[3969]: 1927B926 r   (reader)   87 02 00 00 03 00 00 28
Dec 24 19:26:16 osmio4kplus daemon.info oscam[3969]: 1927B926 r   (reader) FRANSAT [internal] Answer from cardreader:
Dec 24 19:26:16 osmio4kplus daemon.info oscam[3969]: 1927B926 r   (reader)   90 00
Dec 24 19:26:16 osmio4kplus daemon.info oscam[3969]: 1927B926 r   (reader)   87 02 00 00 03 00 00 11
Dec 24 19:26:16 osmio4kplus daemon.info oscam[3969]: 1927B926 r   (reader)   87 04 00 00 07
Dec 24 19:26:16 osmio4kplus daemon.info oscam[3969]: 1927B926 r   (reader)   00 00 00 04 00 00 00 90 00
Dec 24 19:26:16 osmio4kplus daemon.info oscam[3969]: 1927B926 r   (reader)   87 06 00 00 04
Dec 24 19:26:16 osmio4kplus daemon.info oscam[3969]: 1927B926 r   (reader)   01 02 09 01 90 00
Dec 24 19:26:16 osmio4kplus daemon.info oscam[3969]: 1927B926 r   (reader) FRANSAT [internal] using ecm #901 for long viaccess ecm
Dec 24 19:26:16 osmio4kplus daemon.info oscam[3969]: 1927B926 r   (reader)   CA AC A4 00 00
Dec 24 19:26:16 osmio4kplus daemon.info oscam[3969]: 1927B926 r   (reader)   CA B8 00 00 07
Dec 24 19:26:16 osmio4kplus daemon.info oscam[3969]: 1927B926 r   (reader)   A4 05 01 A1 4E 14 4F 90 08
Dec 24 19:26:16 osmio4kplus daemon.info oscam[3969]: 1927B926 r   (reader) FRANSAT [internal] type: Viaccess (non-standard atr), caid: 0500, serial: 7001216079
Dec 24 19:26:16 osmio4kplus daemon.info oscam[3969]: 1927B926 r   (reader)   CA A4 00 00 00
Dec 24 19:26:16 osmio4kplus daemon.info oscam[3969]: 1927B926 r   (reader)   CA C0 00 00 1A
Dec 24 19:26:16 osmio4kplus daemon.info oscam[3969]: 1927B926 r   (reader)   FF F4 00 00 00 80 FF FF FF FF 00 01 02 03 FF FF
Dec 24 19:26:16 osmio4kplus daemon.info oscam[3969]: 1927B926 r   (reader)   FF FF FF FF 0A FF FF FF FF FF 90 00
Dec 24 19:26:16 osmio4kplus daemon.info oscam[3969]: 1927B926 r   (reader)   CA AC A5 00 00
Dec 24 19:26:16 osmio4kplus daemon.info oscam[3969]: 1927B926 r   (reader)   CA B8 00 00 06
Dec 24 19:26:16 osmio4kplus daemon.info oscam[3969]: 1927B926 r   (reader)   A5 04 A1 4E 14 4F 90 08
Dec 24 19:26:16 osmio4kplus daemon.info oscam[3969]: 1927B926 r   (reader)   CA A4 02 00 00
Dec 24 19:26:16 osmio4kplus daemon.info oscam[3969]: 1927B926 r   (reader)   04 19 58 00 00 E6 FF FF FF FF 00 01 02 03 FF FF
sophie101
* Currently
belgium
OK, so here is what I recommend:
1. Disable the oscam stuff in the OpenVIX ( or OpenPLI / ATV ext) menu.
I stopped it from autostarting using these menus from the remote control:-
Menu -> Setup -> Softcam Manager -> Softcam manager -> press the blue button to toggle to Disable Startup.
This is because this reads the config from /etc/tuxbox/config instead of /etc/tuxbox/config/$OSCAM_VERSION
2. Install the latest oscam from the repos.
I doubt the version matters so long as it is recent.
The version as I write is 1.20+svn11726-r2
opkg install enigma2-plugin-softcams-oscam-latest
Installing this package will create the directory /etc/tuxbox/config/oscam-latest that we will use later.
3. Nuke the existing oscam.server, and add new config.
I nuked it bcause I was just using this for Fransat. The other settings just got in the way.
I have removed the aeskeys as per forum rules. Please replace ADD_YOU_AES_KEYS_HERE with the keys, which you can probably find via Google on a forum.
>/etc/tuxbox/config/oscam-latest/oscam.server && cat <<EOF > /etc/tuxbox/config/oscam-latest/oscam.server
[reader]
label = FRANSAT
protocol = internal
device = /dev/sci0
autospeed = 0
caid = 0500
needsemmfirst = 1
detect = cd
aeskeys = ADD_THE_AES_KEYS_HERE
emmcache = 1,1,2,0
mhz = 450
cardmhz = 450
group = 9
lb_weight = 560
EOF
4. Nuke the existing oscam.user, and add new config.
>/etc/tuxbox/config/oscam-latest/oscam.user && cat <<EOF > /etc/tuxbox/config/oscam-latest/oscam.user
[account]
user = dvbapiau
pwd = dvbapiau
keepalive = 1
monlevel = 4
au = 1
group = 1,2,3,4,5,6,7,8,9,10,64
EOF
5. OPTIONAL: If you want your Oscam to log to syslog, which means you can read the messages in /var/log/messages, and you have not configured this already, then add this:
sed -i '/\[global\]/a logfile                       = syslog' /etc/tuxbox/config/oscam-latest/oscam.conf
You can check if this was already done with this:
grep logfile /etc/tuxbox/config/oscam-latest/oscam.conf
If you get output similar to this, then it was already done.
logfile = syslog
6. Test your oscam config on the command line with:
/usr/softcams/oscam-latest --config-dir /etc/tuxbox/config/oscam-latest --daemon -S -d4 -restart 2 --utf8 2
You can see what is happening if you tail the logfile with this command. You can exit the logging by pressing "Ctrl C"
And set your TV to FRANCE 2 on 5W, and see if it works.
Mine took a few seconds to start decrypting the TV channels.
Others mentioned ten mins, but I suspect the few seconds is more likely.
If you get nothing check that you card is inserted in the right way up. I leant the hard way. ;)
If it works then kill oscam with this. (You can run this a few times if you are unsure if the process is killed.)
pkill oscam
7. Set this oscam to start at boot.
update-rc.d softcam.oscam-latest defaults 3
8. Test the start scripts work
Start oscam:
/etc/init.d/softcam.oscam-latest start
Change channel to a France channel and see if it works.
Stop oscam:
/etc/init.d/softcam.oscam-latest stop
The channel you were watching should freeze.
9. If Step 8 works, then reboot, and see if all comes up.
reboot
or use the remote control reboot : Menu -> Standby & Restart -> Reboot
10. Good luck :-)
LeBelge
2x Triax TD 110, 2x Edision OS Mio 4K (plus), Edision OS Mini 4K, Edision OS Nino Pro
Belguim
what you are doing is illegal
dreambox1959
46.3N-4.3E-FRANCE
france
the use of the official card in a device other than the approved receiver is not illegal:
I witnessed a trial between Viaccess and Powercam and the courts acquitted Powercam.
What would be illegal would be to operate in emulation mode.
the dialogue between card and receiver is based on the Eurocrypt protocol which is royalty-free.
sophie101
* Currently
belgium
No, it is not.
Or show us the proof.
At best this might be a breach of contract with many providers, but this is hard to see what laws a provider could enforce.
If anything, Fransat are in breach of Article 3(1) of the Audiovisual Media Services Directive (AVMSD), which provides that member states “shall not restrict retransmissions” of broadcasts from another member state, which is what Fransat are doing.
Cardsharing is illegal outside your own network, but this thread is not about that activity. I have my own Fransat card, which by the way was much cheaper to buy new from Amazon than what you wanted to charge me for yours. Enough said.
I should say that we are covered.
Merry Christmas!
LeBelge
Belguim
III. UTILISATION DE LA CARTE
La Carte d’accès fonctionne exclusivement avec un décodeur ou module TV portant les logos «FRANSAT» et «Via Eutelsat» et ne peut être vendue séparément sauf en cas de remplacement pour SAV ou renouvellement de la Carte. La Carte FRANSAT UHD fonctionne exclusivement dans un équipement UHD labellisé «FRANSAT UHD» pour bénéficier des services en qualité UHD.
Remarque importante : à la suite de la mise en place de nouvelles dispositions techniques de lutte contre le piratage le 6 mai 2019, si vous insérez votre Carte FRANSAT dans un équipement non compatible pour recevoir les offres TV payantes en option, alors celle-ci deviendra définitivement inopérante pour accéder à l’avenir à ces offres TV payantes, même dans un équipement compatible. Pour savoir si votre équipement est certifié compatible avec les offres TV payantes en option, déclarez-le dans votre Espace Client sur www.fransat.fr rubrique « Équipements ».
VII. CONDITIONS D’UTILISATION
Pour recevoir le bouquet FRANSAT, vous devez être muni à la fois d’une Carte d’accès conditionnel et du décodeur ou module TV FRANSAT portant les logos « FRANSAT » et « Via Eutelsat ».
So,
"exclusivement avec un décodeur ou module TV portant les logos «FRANSAT»"
means that Fransat does not allow you to use the PC7 card in Enigma2.
Now you are illegally using the services of Fransat.
Feel free to ask Fransat by e-mail if they agree for you to use Enigma2.
p.s.
N.B. : I'm not selling anything
sophie101
* Currently
belgium
You misunderstand the difference between a breach of contract, civil law, and criminal law.
A company can write what they like in B2C sales, but it does not make it legal, and breaching a contract does not equate to an illegal activity. A company can wrote what they like.
It is similar to a region free DVD player, or rooting your Android phone. Companies tried to sue but failed.
EU law and Directives trump national laws and companies.
Card sharing is not illegal in practice. What is illegal is selling services and profiting from items you are not permitted to sell, which infringes on copyright law and a few others as well.
Case 1 - A person has a legitimate subscription registered to his / her property. They use the third party software to share their very legitimate sub to another receiver in their home which is registered with the provider. There is no infringement on any law in this land (UK), and anybody who says there is will need to point me in the direction of the case which has the law / statute behind it.
In case 1 - if the person with the legitimate sub shares it with themselves even at another property i.e. a 2nd home, where only they will access the service that is subscribed too will be hard pushed to be breaking the law.
However, if at any point you resell these services you are breaking lots of laws which carry severe penalties.
In the UK (same for EU given that laws are pretty much transposed into UK law. Even post Brexit laws remain similar along with International Law) it can almost certainly be that there will never be a case of anyone being prosecuted when they are sharing with themselves or not for profit, and the reason being that if the providers lost the case that - which I think they would, that would set a precedent and it would be open season.
So in answer to the question, 3rd party software used with recievers is not illegal at all. If you think different point me in the direction of laws where people have been prosecuted who have not been selling a service they are not entitled too.
-much info plagiarised taken from text on www.world-of-satellite.com-
sophie101
* Currently
belgium
@Mods
Would you mind closing this thread, because it has served its purpose.
