Advice Needed Receivers with the lowest Symbol Rate?
suedschwede
2.7m Laminas+Polarmount+JPC-Posi+SF8008
DE
Copy the driver to this location (don't forget to set file permissions 755!), first rename the original driver to keep it.
The "e2_changes_20231223.diff" must be recompiled with enigma after patching.
ocean04
Vaasa
Western Finland (63N 22E)
it works with all image or only with openvix?
Driver should work in all images if kernel 5.15.0 is used.
You see that in driver path /lib/modules/5.15.0/extra/
Reboot after update driver (not just enigma2 restart)
In latest OpenVix image (without enigma2 changes) you should see unlocked signal briefly in signal finder. Only after enigma2 changes it updates continuously. Enigma2 changes tested only OpenVix
frankviana
Satellites/tv
Brazil
Only for osmio4k or osmini4k too?
I have osmini4k.
Thx.
ocean04
Vaasa
frankviana
Satellites/tv
Brazil
Ok. Waiting this changes for osmini4k too, because I think both have same tuner.
Thanks.
MCelliotG
Thessaloniki, Greece
Yes, the driver can be tested if replaced, at least for low SR. For no lock signal, the image has to be built. Maybe our friend @ocean04 can share the image he built for testers to flash.
jsda30
edision os mio 4k
spain
im testing...
lnb inverto ultra black
glamour aura skin
openpli 8.3
with 5.15.0 on lib, permission 755 and reboot
but not works
ocean04
Vaasa
but not works
What is not working for you?
Tested driver post #277. Unlocked signal working and also 10492H
Low symbolrate did not seem to work, possible this change was not included
jsda30
edision os mio 4k
spain
i done a manual searching at 10498 tp and not get any channel
stephan94
Bavaria
To make the LNB work we will need to power it with a voltage of 13V to 18V?? because i have a DISEqC 1.0 a 1.2 16x1 EMP-CENTAURI + 1/1 TDT for my dishes...
thanks for your support
Here is the setting with the modified LNB
jsda30
edision os mio 4k
spain
maybe i have something wrong there....
suedschwede
DE
There was still a small problem with the driver from post #277. Since I can no longer delete it, I'm attaching it here again.
Tested OK :)
  • 10955H 789.log.txt
  • avl6261.ko.zip
jsda30
edision os mio 4k
spain
MCelliotG
Is 555 the lowest SR? Has anyone tried even lower?
jsda30
edision os mio 4k
spain
geat mcelliotg ill try this evening night! and i tell
yesterday didnt work... but today new file patch
jsda30
edision os mio 4k
spain
at 26e tp like 10494 not get! now im trying to move mi dish to get at 8w radio maria with 256 SR with octagon sf8008 not problem
frankviana
Satellites/tv
Brazil
I tried same driver using my osmini 4k and tune SR 666
suedschwede
DE
Found with blind scan or normal channel search? With Blindscan I haven't had any luck getting anything below SR1000 with the Mio.
HTML:
<?xml version="1.0" encoding="iso-8859-1"?>
    File created on Donnerstag, 28 of Dezember 2023, 23:43:38
    using osmio4k receiver running Enigma2 image, version 7.3,
    build 20231222, with the blindscan plugin
    Search parameters:
        Tuner A: Availink AVL6261 (DVB-S2X)
        Satellite: 26.0E Ku-band Badr 4/5/6/7/8
        Start frequency: 10489MHz
        Stop frequency: 12750MHz
        Polarization: vertical and horizontal
        Lower symbol rate: 100
        Upper symbol rate: 60000
        Only save unknown tranponders: no
        Filter out adjacent satellites: no
        Scan duration: 324 seconds
<satellites>
    <sat name="26.0E Ku-band Badr 4/5/6/7/8" flags="0" position="260">
        <transponder frequency="10498000" symbol_rate="27500000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="10529000" symbol_rate="27500000" polarization="1" fec_inner="0" system="0" modulation="1" />
        <transponder frequency="10970000" symbol_rate="27500000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="11010000" symbol_rate="27500000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="11018000" symbol_rate="3330000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="11230000" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1" />
        <transponder frequency="11270000" symbol_rate="27500000" polarization="1" fec_inner="4" system="0" modulation="1" />
        <transponder frequency="11472000" symbol_rate="4166000" polarization="1" fec_inner="6" system="1" modulation="1" />
        <transponder frequency="11919000" symbol_rate="27500000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="11938000" symbol_rate="27500000" polarization="1" fec_inner="4" system="0" modulation="1" />
        <transponder frequency="11958000" symbol_rate="27500000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="11977000" symbol_rate="27500000" polarization="1" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="11996000" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1" />
        <transponder frequency="12054000" symbol_rate="27500000" polarization="1" fec_inner="4" system="0" modulation="1" />
        <transponder frequency="12073000" symbol_rate="27500000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="12092000" symbol_rate="27500000" polarization="1" fec_inner="4" system="0" modulation="1" />
        <transponder frequency="12111000" symbol_rate="27500000" polarization="0" fec_inner="4" system="0" modulation="1" />
        <transponder frequency="12130000" symbol_rate="27500000" polarization="1" fec_inner="3" system="0" modulation="1" />
        <transponder frequency="12149000" symbol_rate="27500000" polarization="0" fec_inner="4" system="1" modulation="2" />
        <transponder frequency="12169000" symbol_rate="22000000" polarization="1" fec_inner="3" system="1" modulation="1" />
        <transponder frequency="12182000" symbol_rate="16200000" polarization="0" fec_inner="3" system="0" modulation="1" />
        <transponder frequency="12226000" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1" />
        <transponder frequency="12245000" symbol_rate="27500000" polarization="1" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="12303000" symbol_rate="27500000" polarization="0" fec_inner="4" system="0" modulation="1" />
        <transponder frequency="12360000" symbol_rate="27500000" polarization="1" fec_inner="4" system="0" modulation="1" />
        <transponder frequency="12380000" symbol_rate="27500000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="12418000" symbol_rate="27500000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="12437000" symbol_rate="27500000" polarization="1" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="12456000" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1" />
        <transponder frequency="12476000" symbol_rate="27500000" polarization="1" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="12523000" symbol_rate="27500000" polarization="1" fec_inner="4" system="0" modulation="1" />
        <transponder frequency="12523000" symbol_rate="27500000" polarization="0" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="12563000" symbol_rate="27500000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="12608000" symbol_rate="26000000" polarization="1" fec_inner="0" system="1" modulation="4" />
        <transponder frequency="12643000" symbol_rate="27500000" polarization="0" fec_inner="4" system="0" modulation="1" />
        <transponder frequency="12656000" symbol_rate="10000000" polarization="1" fec_inner="0" system="1" modulation="5" />
        <transponder frequency="12683000" symbol_rate="27500000" polarization="1" fec_inner="3" system="0" modulation="1" />
    </sat>
</satellites>
frankviana
Satellites/tv
Brazil
Normal channel search (signal finder)
