suedschwede
- 2.7m Laminas+Polarmount+JPC-Posi+SF8008
- DE
will be great if u finally build for sf8008 for get 10494 tps at 26ee2_changes_*.diff.txt is for minimum reception when there is already a very low signal, for this, enigma² or the image must be rebuilt and is for all boxes.
avl6261_*.diff.txt is only intended for the Mio4k tuner driver.
My Testbuild.
where can be place the e2 changes diff file on box?e2_changes_*.diff.txt is for minimum reception when there is already a very low signal, for this, enigma² or the image must be rebuilt and is for all boxes.
My Testbuild.
i was testing with edision os mio 4k and tnpa-5 image and not get the 10492 tps at 26eThere will be nothing for the SF8008, the drivers are closed source.
For this purpose, a converted LNB and an LNB-LOF that has been offset in the settings must be used.
jsda30 wrote that he had an Inverto black ultra ( post 287) it must workin addition to support in the image, you also need an LNB ( if you are trying to use a Universal LNB ) that still partially works outside the specified band (ie the output filter does not suppress frequencies below 950 MHz)
- Bullseye Ultra High Stability Single LNB for QO-100, 2ppm TCXO
- Single output
- PLL synthesised design with 2 PPM TCXO
- Factory calibrated to within 1 kHz
- 25MHz reference output
- Universal 40mm LNB fixing
- Reception range 10.489 - 12.75 GHz
- L.O. frequency, low band 9.75 GHz
- L.O. frequency, high band 10.6 GHz
- IF output, low band 739 - 1950 MHz
- IF output, high band 1100 - 2150 MHz
- LO frequency stability at 23C +/- 10 kHz
- LO frequency stability -20 to 60C +/- 30 kHz
- Noise figure 0.5 dB
Hii was testing with edision os mio 4k and tnpa-5 image and not get the 10492 tps at 26e
for me not work... i have a 90 cm dish here in canary islands!!
hi bandido happy new yearAlso,
More modifications were added so blindscan would work on finding transponders below 1000SR. The enigma2-plugin-extra-avl6261-t2mi-700mhz-europe_5.15.0 plugin should have the changes shown in the attached patch file. TNAP images makes a report after every scan and installs it in /tmp of receiver files.
You may also put a folder on usb drive named ServiceScan to get these reports on usb. A scan report of 117w c band is attached and shows found transponders down to 675SR. This scan was done using the Europe plugin.
Ku Blindscan is slow and seems to be somewhat corrupted. But it does work. The Ku blindscan works much better when the frequency range is not extended. The enigma2-plugin-extra-t2mi-module-tnap-mod_5.15.0 Does Not have extended frequency and works better on Ku blindscasn.
You must install avl6261-low-symbol-rate-Europe.plugin otherwise it will not worki installed the plugin extra t2mi module
but not get the 10492 tp at 26e
maybe i need a special lnb.. now i have inverto ultra black lnb....
or ill must to install this: avl6261-low-symbol-rate-Europe.patch
now im remember that i didnt get 755 permission
where its locate at box the file... for give permission¿
thanks for your replay stephanYou must install avl6261-low-symbol-rate-Europe.plugin otherwise it will not work
but first you need to uninstall the extra t2mi module plugin which is not for europe.
with the LNB that you have 10492 works without problem
yes i have it@jsda30 :
Do as el bandido indicated in post 331,
we must not complicate what is simple.
