That's how TNAP always works, you have a choice of several optionsIt is 4x the tuner driver with different features and functionality, I just looked at it.
for me not work with 10492 tp 1500 sr at 26e!.here is the T2MI search result in blindscan with the plugin "avl6261-t2mi-700mhz-europe (5.15.0)".
everything works perfectly ( satellite 40° East)
View attachment 153836View attachment 153837View attachment 153838
Yes, I did see your LNB.did u see my lnb?
Hello Stephan,a record; a frequency with an sr of 500 has been locked (amateur radio)
View attachment 153655View attachment 153656View attachment 153657
Hello tompouceHello Stephan,
I'm still happy with my old SF4008. For ex., it works very good with the SR 543; on Eut 5WB, 11453H 1/2 Qpsk, french radios ; locked with 12.20 dB (snowy day)![]()
Thanks, ¿what image version of open ATV allows an SR value of below 1000 to be entered?.........from memory the range was 1000 min to 60000 max. Perhaps amended driver config needed..........appreciated.................."SF8008 is still the best STB for low SR".
Thank you 'MCelliotG' for the info........will play with the receiver later.In manual search you can enter whatever value you need, the 1000 limitation is for the blindscan plugin settings.
Thanks 'MCelliotG' for the info, will play later with the receiver.In manual search you can enter whatever value you need, the 1000 limitation is for the blindscan plugin settings.
how do you start a scan for this channel from this screen?
You just press OK on the remote. That's how it works on my Dreambox anyway..how do you start a scan for this channel from this screen?
On receiver:- 'Main Menu/Setup/Reception/Manual Scan' then scroll down to 'Type of scan', change value to read 'User defined transponder' then input/change all the column values to agree with your intended transponder search.......... press 'OK' button to make your search. Good luck.how do you start a scan for this channel from this screen?
