OCTAGON SF8008 E2 4K UHD
EnoSat
enosat.euweb.cz
Slovakia
SimonE
Gloucestershire, UK
I have just done a firmware update on my SX88+ from 1.04.50 to the latest 1.06.04 . It sits in a cabinet next to my SF8008 and since doing the update my SF8008 controller controls BOTH receivers. I put version 1.04.50 on a USB stick to try and go back but it wouldn't let me. I surely can't be the first to have this problem. Has anyone else suffered this and what's the cure please.
You should be able to factory reset the 88, then use the stick.
SimonE
Gloucestershire, UK
Thanks guys for your advice. My SX88+ has been restored to v 1.05.50 firmware. The problem of my SF8008 rcu controlling my SX88+ has now gone. Deep Joy!
Octagon SF8008 Supreme:
KEY FEATURES:
– Dual OS: E2 Linux & Define OS Linux
– 4K H.265 HEVC UHD processor (3840 x 2160)
– Hisilicon Hi3798MV200 Huawei
– Quad Core 64Bit (4x 1.6GHz) 15000 DMIPS
– Flash 8GB eMMC
– RAM 1GB DDR4
– Internal M.2 slot (M.2 SSD: M KEY – PCIE NVME)
– Gigabit LAN Ethernet (1000Mbps) network interface
– Fixed 2.4/5G dual-band WiFi (WLAN) up to 1200Mbps, 2x WiFi antennas
– 4-digit 7-segment display
– CA card reader
– Hardware BlindScan (blind search)
– DVB-S2X & DVB-C/T2 Combo (2xTuner) + Multistream Support
– Multiroom Client & Sat to IP Client Support
– HDMI 2.0a & USB 3.0
– MicroSD slot
– HDMI CEC support
– Learnable remote control
SPECIAL FEATURES:
– DUAL OS: E2 Linux OS operating system & OCTAGON Define Linux OS
– DVB-S2X 4K UHD & Multistream (T2-MI direct input)
– Symbol rates from 100 – 80,000 SR
– PIP HD & UHD (Picture in Picture)
– HDR 10bit & HLG
– Multi Transcoding & Multiroom
– Sat>IP Client & V-tuner USB dongle
– Blind scan (blind search)
– Media libraries of public broadcasters
– HW Multiboot
– ffmpeq HW playback support
– 2160P Media Playback H.264 and H.265
– OTA updates
– DiSEqC 1.0/1.1/1.2, USALS, Unicable, Fast Scan
– PVR recordings (*optional)
– 12V connection (also suitable as a camping receiver for motorhomes or caravans. 12V car adapter not included)
– 0.5W standby
FRONT SIDE:
– Power button on/off button
– LED display (red / blue)
– IR sensor (infrared receiver)
BACK:
– H.265 4K UHD DVB-S2X & DVB-C/T2 tuner LNB input
– Dolby S-PDIF
– AV – Audio Video socket – Jack to RCA
– RS-232 socket (maintenance & service)
– WiFi 2x WiFi antennas
– HDMI 2.0a output
– USB 2.0 port
– Network Gigabit LAN (1000Mbps)
– MicroSD slot
– Recovery (Reset) button
– DC-12V power supply
– Power switch on/off
RIGHT SIDE:
– USB 3.0 port
– Card reader (CA CARD)
INSIDE:
– M.2 slot for internal SSD hard drive (M.2 SSD: M KEY – PCIE NVME)
TUNER & DEMODULATOR:
– DVB-S2X: Availink AVL62X1 & RDA5815m
– DVB-C/T2: Altobeam ATBM7821
MISCELLANEOUS:
– Dimensions (LxDxH) 220mm x 125mm x 40mm
– Power supply (power supply) DC12V-2A
– 139.90 euros
Front
Side
innards
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
a real beast !!! .. shame Ci+ is missing
MCelliotG
Thessaloniki, Greece
In short, basically another SF8008 with OSmio's tuner.
I would be interested if it sported 8GB RAM, 128GB flash (and a preinstalled 512MB M2)!
cokeaddict
Vu+ Ultimo4K, Uno4K SE, Uno4K, Solo4K, Zero4K, Duo2, SoloSE v1 & v2, Solo2, Ultimo, Uno, Duo, Motorised CM 1.2m dish, Hybrid Titanium Smart Lnb with CM feedhorn and a Zone2 minidish with Inverto Unicable II
53°E - 45°W
Then it would be too expensive for anyone to buy it.
2GB ram and 16GB flash without the pre-installed NMVe would have kept the price sensible and still been a nice upgrade.
dmaavrigdo
1.2m Laminas OFC1200 dish
Inverto Quad Black Ultra IDLT-QDL412-ULTRA-OPN
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
My supreme twin is on it's way. Is there a way to stop one remote controlling both my SF8008s?
jsda30
edision os mio 4k
spain
great keep us informed beacuse new sf8008 Symbol rates from 100 – 80,000 SR
so will be great if it can get radios with low SR under 256
MCelliotG
Forget SR lower than 500, it now has Availink, same tuner as OsMio. And it's not even a certainty the images have implemented the E2 changes @ocean4 suggested.
EnoSat
enosat.euweb.cz
Slovakia
Do not forget that there is an input tuner before the input demodulator
Ustym 4K PRO TWIN S2X - AV2018 + AVL62X1
Octagon SF8008 - RDA5815M + Si2166D
Octagon SF8008 SUPREME - RDA5815m + AVL62X1
EDISION OS mio+ 4K - AV2018 + AVL6261C / AV2018-MxL608 + AVL6862TA
MCelliotG
Interesting. We'll find out soon.
hatters1976
Satellite dish: 1x 2.40, 1 wave frontier T90 (7e-46e). Octagon, gt media gt combo-v8x. Football and basketball feeeds enthusiast.
GR
At the moment i have sf8008 twin sat tuner ... and it is not satisfactory at all in some satellites.
Do we have an idea how much is the difference regarding the tuner sensitivity performance in comparison new supreme
or os mio 4k ? thanks
EnoSat
enosat.euweb.cz
Slovakia
the input tuner (RDA5815) did not change, only the input demodulator (Si vs. AVL) changed - so the sensitivity will be approximately the same
I have both twin tuner and combo 8008 receivers and have not found much of a difference. They are early models however.
hatters1976
GR
that means because i need a sensitive tuner which enigma2 linux model has the best from this point of view?
Edision os mio 4k this old receiver or is there any other recent choice anyone knows? thanks for your opinions
Try the Android from GTMedia. The Combo is highly rated.
hatters1976
GR
I have done a research and i do not see any other enigma2 linux receiver to arrive soon.
The only thing is i do not know much for novaler pro 4k tuner what is it and if it is sensitive too?
Do we expect something else to be out in the market during this year? Thanks.
