Any lnb test reviews lately?
Spc..
TeVii S2 Tuners, 138cm Gibertini + 100cm backup dish
Slovenia
After fine tuning, testing on EBU feeds i get +3 to +4dB more.
I am testing in on low signals and feeds, so lower symbol rates than normal programs.
Gibertini 125cm (official) if i measure it it is more like 138cm (unofficial) + new ultra
Tested with BLSCAN2.exe and TeVii S662
OS:
Windows Server 2022 Datacenter
7°E | Horizontal, EBU NEWS EXCHANGE (low signals):
OLD Ultra Black (Fine Tuned):
11050.185 Mhz, 4936 KS, DVB-S2/8PSK, 3/4, 6.0 dB
11056.183 Mhz, 4936 KS, DVB-S2/8PSK, 3/4, 7.0 dB
New Ultra (Fine Tuned):
11050.185 Mhz, 4936 KS, DVB-S2/8PSK, 3/4, 9.0 dB (+3dB )
1056.183 Mhz, 4936 KS, DVB-S2/8PSK, 3/4, 9.0 dB (+2dB )
7°E | Vertical, UPLINKS, World-Feed-A-C1 (low signals):
11162.982 Mhz, 7199 KS, DVB-S2/8PSK, 3/4, 7.0 dB
11162.860 Mhz, 7199 KS, DVB-S2/8PSK, 3/4, 10.0 dB (+3dB )
7°E | Vertical, UPLINKS, World-Feed-A-C2 (low signals):
11171.153 Mhz, 7199 KS, DVB-S2/8PSK, 3/4, 6.0 dB
11171.229 Mhz, 7199 KS, DVB-S2/8PSK, 3/4, 10.0 dB (+4dB )
7°E | Vertical, UPLINKS, ENC-4 (low signals):
12735.926 Mhz, 7199 KS, DVB-S2/8PSK, 3/4, 7.0 dB
12735.894 Mhz, 7199 KS, DVB-S2/8PSK, 3/4, 11.0 dB (+4dB )
On uplinks i get arround 2-4dB more with new ultra.
cwsat
Gibertini 85cm / Dragonsat 3000 motor / Inverto Black Ultra LNB
Midlands
Looks good.
Where are you based? Any other sats you can test, 26e?
Spc..
Slovenia
Looks good.
Slovenia, Maribor, near Pohorje hills.
Yes i can test other sats but at the moment i am trying to setup 0.8°W for Roger Waters.
0.8°W | Horizontal, Normal program, normal signal
12168.693 Mhz, 30001 KS, DVB-S2/8PSK, 3/4, 14.0 dB
12168.684 Mhz, 30001 KS, DVB-S2/8PSK, 3/4, 16.0 dB ( +2dB )
0.8°W | Horizontal, Telenor TEST signal, ID: TEST 13009
12360.497 Mhz, 30001 KS, DVB-S2/8PSK, 3/4, 13.0 dB
12360.485 Mhz, 30001 KS, DVB-S2/8PSK, 3/4, 14.0 dB ( +1dB )
All frequencies are same or max +2 dB better on 0.8°W ( program frequencies , not uplinks ).
0.8°W | Vertical, UPLINK, B 187 DGI
12519.339 Mhz, 2078 KS, DVB-S2/8PSK, 3/4, 11.0 dB
12519.249 Mhz, 2078 KS, DVB-S2/8PSK, 3/4, 11.0 dB
Beli1910
Sevnica-Slovenija
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica 8290-Slovenija
can you make a comparison between Lnb according to the table I set up - so we can see exactly where we are.
Ozumo See how much the Ibu single outperforms the ibu Twin in the 10.7-11.2 Ghz range. Or compare the Ibu single in this range with ordinary Lnbs. You can use 19E-13E and tell me what result you will get.
Sorry for the delay... 7°E 11056H 4937, all DRO IBUs, oldest to newest:
Single 1: 10.0 to 10.3dB
Single 2: 10.0 to 10.3dB
Twin 1: 10.6 to 11.1dB
Twin 2: 10.3 to 10.6dB
Blue PLL was 10.3 to 10.6dB.
ymttt
5 meter fiber dish, modified mti highline lnb, tm5402 m3 receiver
Ghana, West Africa
Guys, can anyone help with information on which shops still have the Golden Media 202+ in stock? It appears its becoming difficult to get these days.
cwsat
Midlands
Guys, can anyone help with information on which shops still have the Golden Media 202+ in stock? It appears it’s becoming difficult to get these days.
Your best chance is probably eBay. I’ve not long sold one on there.
MCelliotG
Thessaloniki, Greece
I recently installed the new Black Ultra lnb on my setup to replace my 8year old Black Ultra.
Now, to be fair I didn't notice any significant change, everything is quite the same, except on 36E where I now have 5 frequencies locked on the South African beam, while I had only 2 with the old black Ultra.
cwsat
Midlands
Still love the old Smart Titanium twin on my dish. Edges the new Black Ultra for me.
ymttt
Ghana, West Africa
Do we know of any lnb which is a champion on horizontal signal? I intend to pull in some H signals on hispasat.
Manikm909
Small'ish Dish Man
Kent, UK
technomate golds are also decent
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Here on the forum, we tested a large number of lnbs in real time and with a professional measuring instrument. Go through the topic, just turn on translate to understand what was written and look at the pictures. For each system or antenna on which a list and picture of the Lnb is added - This shows which lnb gives the best results for a certain satellite. I hope it will help you.
Link:
jojoz
Emme Esse 115 Alu satellite dish
Stab HH120 diseqc motor
Golden Media High Gain Quad LNB 204+
Octagon SF8008 single satellie receiver
Athens Greece
I have a quad golden media 204+ on my dish and compared to the IBU quad (the new and the old one) I get better results especially on feeds.
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
For satellite 28E, this is quite understandable. IBU has very bad results on this satellite.
AtOM13
near Marseille
Triax 100 cm, lnb Inverto black Ultra
Laminas 150 cm
Marseille
8.0°W 11053 H 27500 beIN Sports...50%=====52%==========52%================52%============61%=====
Hi william-1 ,
So if I understand well, on 8w you get 50% with Inverto black ultra and 61% with Inverto PLL ? Both LNB are single model ?
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
These are not two different Lnbs, but both Inverto. I suggest that if you use a motorized system, you try the Diavla red. This lnb is very well found on the whole clark.
AtOM13
near Marseille
Laminas 150 cm
Marseille
Thanks but I’m not using motorized system.
Got Lamimas 150 with IBU (new model) and trying to received 11013 H and 11054 H on 8W ( 12604 H on 8W ok 70% )
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
It's a shame for such an antenna to be fixed. The Ibu old model is a bit better than the new model. I recommend that you get the Ibu twin, but again I'm talking about the rotating system. But where is your location and what is the satellite coverage according to your home address.
AtOM13
near Marseille
Laminas 150 cm
Marseille
No need to motorized the dish, already have another dish for Astra, HB, Thor with multi LNB ^_^
Just want to received 2 missing frequencies for Bein Mena on 8w with the 150 Laminas ( location near Marseille)
So if william-1 can confirm that he haves 10% more with the Inverto PLL, I’ll try it too
AtOM13
near Marseille
Laminas 150 cm
Marseille
Hi william-1 ,
Yesterday test with Laminas 150 cm dish
- Inverto black ultra (new) 68% SQ
- Inverto Prenium PLL ( blue) 70% SQ
8w 12604H frequency, still not received 11013H and 11054H
