Eutelsat Hot Bird 13F & 13G
rodscha
the 8 FTA programs on 2 transponders now work fine ,the Folklore ones a tad weaker than the news & docs ones.
Nalleman
Motala Sweden
Sweden
There might be further adjustments but right now (and the entire day so far) it looks like this at my place with the 1,1 m antenna (outside Linköping in Sweden):
12616 H: 14,7 dB
12635 V: 15,2 dB
12654 H: 14,8 dB
12713 V: 14,7 dB
So stable reception! Glad to get City TV again (used to be at 16 E but was moved to 45 E).
No signal on any of the Bulgarian frequencies this evening. Everything else is ok so guess they have been turned off or changed to a different modulation type.
iandoh
Pärnu. Estonia/Burgas, Bulgaria
1m Mutlibracket (19e, 13e, 10e, 9e, 4.8e) & 1.2m @ 28e
They're all coming in well here. I really do believe this is a test of the spot beam and they're seeing how it works atm.
stel883_
"34.5W-70.5E - Gibertini OP125L, Actuator 18", Superjack 3618, Moteck Vbox2, IBU PLL Single, DM900 RC20 UHD 4K" "45W-70.5E - Gibertini OP100L, Moteck SG2100A, IBU Single, Edision OS Mini 4k" "Tivusat Gold Card & Cam" "Toshiba 32L3963DG"
"Fujitsu Lifebook S752 - Windows 10 64-bit"
Vátika, Greece
Gibertini OP125L, Southern Peloponnese, Greece
wellikan
satdx.club
Dr.HD 1000 Combo, Denys H.265, TBS 6903
GIBERTINI OP 150 S
Ireland
With the inclusion of the new transponders of the package VIVACOM yesterday morning there was a powerful signal:
Today, having checked once again, the power of these frequencies can be said to have disappeared :cry:
Beli1910
Sevnica-Slovenija
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica 8290-Slovenija
Yes, they directed the beam where it needed to be. Unfortunately, you have now lost the signal in your geographical area. I am reading and see that the signal has noticeably increased in Bulgaria. Somewhere as much as it has dropped in yours. I have not monitored the signal for the last few days, but I have checked today or I always have 17db in Slovenia.
Nalleman
Motala Sweden
Sweden
Outside Linköping (southern part of Sweden) no change.
Strength is the same as yesterday as shown in my previous post #502.
Fisty McB
See my signature...
County Tyrone, N. Ireland
Same in N. Ireland - from solid reception to zero! Ah well, I'm guessing that the "superbeam" than was in pre-launch publicity has been given a bit of a steer south-eastwards? Either that or maybe the new Hot Birds have similar beamforming to that of Quantum at 48E.
Yesterday morning the 5 Vivacom transponders were moved to Hotbird 13G.
While last night another 2 transponders were moved to 13G and 6 transponders were moved to 13F.
Below is the list:
Yesterday morning
Txp-95 12616 H --> From 13F to 13G
Txp-96 12635 V --> From 13F to 13G
Txp-97 12654 H --> From 13F to 13G
Txp-98 12673 V --> From 13F to 13G
Txp-100 12713 V --> From 13F to 13G
Last night
Txp-3 11258 H --> From 13F to 13G
Txp-90 12520 V --> From 13F to 13G
Txp-124 10992 V --> From 13G to 13F
Txp-125 11013 H --> From 13G to 13F
Txp-127 11054 H --> From 13G to 13F
Txp-128 11075 V --> From 13G to 13F
Txp-133 11179 H --> From 13G to 13F
Txp-158 11662 V --> From 13G to 13F
Video of the interruptions on youtube:
And from here, you can download with higher quality: http://frequencyplansatellites.altervista.org/file_privati/Hotbird_07032024.avi
This new beam must have a hell of a steep cut off if the Bulgarian muxes are being received well in Estonia & Im getting absolutely nothing on a 1m dish in south eastern Scotland. :oops:
Nalleman
Motala Sweden
Sweden
They are getting well received in Sweden too which is closer to you than Estonia.
ocean04
Vaasa
Western Finland (63N 22E)
Around 9-10db 1.1m here (TD110 little too small)
Butacas
90 cm motorised dish (1 m x 90 cm) + fixed [DiSEqC 3 x 1] {80 cm x 74 cm} Hot Bird 13° E, {65 cm} Astra 19,2° E & {60 cm} Hispasat 30° W + fixed {60 cm} Astra 28,2° E.
Motorised dish currently: 40,5° West to 45° East.
Vu+ Solo SE V2, Vu+ Zero 4K, TBS 5927.
Spain, Galicia (Ourense)
On Vivacom frequencies, which on Tuesday had a very good signal, now I have zero signal. :oops:
italy2006
starsat
iran
no signal in eastern region of Turkey.
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
In Slovenia, the signal varies between 15 and 17 db at gibertini 150. A little worse than it was at the start, but satisfactory.
Nalleman
Motala Sweden
Sweden
Signal up today at my place in Sweden.
All Vivacom TP:s at around 15,5 dB now (1,1 m antenna).
Probably further adjustments will be made so we will just have to wait and see what comes out in the end.
rodscha
today morning,
12713 V 30000,flimsy almost visible
12635 V 30000 ,absent
will return after rain stops... I hope!
That pair of TP is very convenient to fine-tune Hotbird indeed!
Nalleman
Motala Sweden
Sweden
today morning,
How is the signal on the H transponders (12616 and 12654)?
Here there is no difference between V and H.
