New Box
findview
Gigerblue Quad plus
Essex
For the past 10yrs I've been using a Gigablue Quad plus, the only trouble is that it doesn't have streaming.
Could a fellow member advise if it's worth purchasing a 4k streaming box.
What do you think you are currently missing out on with your existing kit ?
findview
Gigerblue Quad plus
Essex
Hi, Channell Hopper, thanks for your reply.
There are many channels that I would like to receive on 9 & 5 degrees which have a lot of streamed services of which I can't receive on my Gigablue.
stel883_
"34.5W-70.5E - Gibertini OP125L, Actuator 18", Superjack 3618, Moteck Vbox2, IBU PLL Single, DM900 RC20 UHD 4K" "45W-70.5E - Gibertini OP100L, Moteck SG2100A, IBU Single, Edision OS Mini 4k" "Tivusat Gold Card & Cam" "Toshiba 32L3963DG"
"Fujitsu Lifebook S752 - Windows 10 64-bit"
Vátika, Greece
Hi, do you mean multistream channels?
The Lyngsat site offers links to channels that can be received with a laptop or mobile phone.
LeBelge
2x Triax TD 110, 2x Edision OS Mio 4K (plus), Edision OS Mini 4K, Edision OS Nino Pro
Belguim
What do you mean by streamed services?
findview
Gigerblue Quad plus
Essex
Yes, I meant multi streaming.
I like to watch sports such as tennis, skiing etc via hotbird & astra (19.2).
However, I would like to watch thr Supertennis channel again which moved from hotbird to eutelsat (9 degrees) about three years ago & now is only available on multiscreen receivers I understand.
Multi streaming as in the satellite transmission format?
Supertennis is transmitted on the 9B Italian spot beam - its not available in the UK.
As for your questions about multistream boxes, thats a personal decision. Are the channels you want to watch available on multistream on a beam that you can receive? If they are & you fancy a new challenge go for it.
findview
Gigerblue Quad plus
Essex
Thanks for your help.
