Actuator 36inch which sats to install in 2.40 dish.
hatters1976
Satellite dish: 1x 2.40, 1 wave frontier T90 (7e-46e). Octagon, gt media gt combo-v8x. Football and basketball feeeds enthusiast.
GR
I just bought a new actuator 36inch to change the very old one. My dish is probably a 2.40 Aris or Famaval
as i noticed it has small holes at the edge for possible extension. My question is which sats to install from west
to east for the dish to be stable and not risky. For example it would be better from 30w to 42e or lets say from
15w to 52e ? thanks in advance!
stel883_
"34.5W-70.5E - Gibertini OP125L, Actuator 18", Superjack 3618, Moteck Vbox2, IBU PLL Single, DM900 RC20 UHD 4K" "45W-70.5E - Gibertini OP100L, Moteck SG2100A, IBU Single, Edision OS Mini 4k" "Tivusat Gold Card & Cam" "Toshiba 32L3963DG"
"Fujitsu Lifebook S752 - Windows 10 64-bit"
Vátika, Greece
Hi, risky would be on the edges of the arc, right? What is your central satellite?
30w to 42e = 72 degree span
15w to 52e = 67 degree span
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
For example it would be better from 30w to 42e or lets say from 15w to 52e
30W to 52E would be less than 90 rotational degrees for latitudes above 51 degree. So why wouldn't you take the whole range?
Where/What is your location "GR"?
(edit: Is it Greece, maybe? I changed my location from "NL" to "The Netherlands", just now, just to be perfectly clear to other members.)
greetz,
A33
hatters1976
GR
South East of Greece near Turkey. Just wanted to know your opinion. I am doing that mostly for the feeds but i
would like to hear opinions about all sats before the dish permanent motorised installation from the technician.
I am thinking of doing 30 west - 42 east ... or 52 east for persiana sports free to air. Currently the dish is almost 7e
but i cannot say if it is exactly central satellite ... i think so...
stel883_
Vátika, Greece
If 23.5e is correct for central satellite, then 53.5 degrees west travel, so you can go east the same, total arc span 107 degrees.
hatters1976
GR
So i understand that 30w-52e should be a safe thing to follow. Thank you all for advice.
I will check with the technician which satellite is the central.
stel883_
Vátika, Greece
For a motorized dish install, you have to align to your true south (geographical postion) for correct tracking of the arc.
stel883_
Vátika, Greece
stel883_
Vátika, Greece
The closet satellite to your location, is your central position for the motorized install.
a33
XSAT410
Rebox RE-9000
The Netherlands
Normally I'd say an actuator setup could easily manage 120 rotational degrees, maybe up to even 140 or 150 degrees, for 'normal' setups. But I've no practical experience with an actuator setup, myself, practical data about this I leave to others.
Visible range (above horizon) southeast greece is about 53W to 104E, 170 rotational degrees. You'd have to check the actual line of sight near horizon at your own location.
Then determine what the "lowest" satellite is that you want to receive (east or west). Put the actuator at that side of the dish, and see to it that that lowest satellite has the lowest possible extensions of the actuator (by mounting extra L-brackets or so). That'll give you widest range along the arc, with least chance of 'flopping' or whatever it is called, at the extended side of the actuator.
When you want to have a rotational range near 170 degrees, I'd recommend you build a custom made bracket that holds the actuator to the mount: that setup will reduce the chance of flopping. It is described here at the forum.
I hope this is all somewhat understandable for you,
greetz,
A33
stel883_
Vátika, Greece
Btw, i only have experience with 1.20 dish and 18" actuator. My arc span is 116 degrees due to mount design.
Try to identify the dish , a documented itemised receipt from your earlier installer may assist your current installer.
a33
XSAT410
Rebox RE-9000
The Netherlands
And you never thought about changing the mount design, to increase the range/arc span?
Greetz,
A33
stel883_
Vátika, Greece
No, i haven't thought about it. I have seen with existing mount a 10 degree increase, but with the OP150S dish.
Here is a video i found, but i don't understand exactly what has been done.
a33
XSAT410
Rebox RE-9000
The Netherlands
Maybe he has added the extended bracket/plate at the top of the actuator, and the bracket at the bottom of the actuator (not L-shaped, but J-shaped)?
However, problem of this mount seems to be that the dish elevation-adjustment brackets touch the mount (collide with it), and then cannot go further. See at about 3 minutes, in the movie; at the extended side. But it is also at the retracted side, of course.
So that limits the possible range. Not an easy thing to fix?
Apart from that he says he has a 24 inch actuator, if I understand him correctly.
Greetz,
A33
stel883_
Vátika, Greece
Transleted text from the comment section.
Per essere precisi, si può aumentare ulteriormente l' escursione installando il Qarl 3624. Per fare questo la modifica è molto più impegnativa, bisogna usare staffe più lunghe e più robuste. Poi bisogna spostare i due bulloni più in basso come evidenziato nel video, notiamo che le due sponde del polar vanno a toccar.
To be precise, you can further increase the travel by installing the Qarl 3624.
To do this the modification is much more demanding, you need to use longer and more robust brackets.
Then you need to move the two bolts further down as highlighted in the video, we notice that the two sides of the polar touch.
stel883_
Vátika, Greece
@a33 Thanks, for explaning it to me, maybe another thread is needed for this. I hope we didn't go off-topic.
Precisely why I closed the thread a couple of days ago, but it has since been unlocked without response from the o/p.
a33
XSAT410
Rebox RE-9000
The Netherlands
I guess he is now consulting his local technician:
When there are remaining questions, I've no doubt he will come back....
Greetz,
A33
The technician was taking a picture of the outdoor equipment last time they were on site,
