RAI DAB+ feed from 5 West
Satfaca
Melmac (46N, 14.5E)
Melmac
No, you should not. Please don't mix them up.
Right, technically not to be mixed up but ... for "organizational & artistic" reasons on my receiver I put them together with DAB.
I could have expressed myself differently in that post indeed.
andimik
120cm with Stab rotor, TBS 5927 and 6903xv1
Southern Austria
EnoSat
enosat.euweb.cz
Slovakia
no, 12603 use normal TS , 11604 use IP
Adam792
Cheltenham
Nice find! It's a copy of 23.5°E 12645 V 2200 (19.2°E 11604 V 2200), with the two WDR DAB multiplexes -
tune-s2 11604 V 2200 -system DVB-S -lnb UNIVERSAL -adapter 1
status Locked | signal -31.8 dBm | snr 15.0 dB | ber 0 | FE_HAS_LOCK
Closing frontend ...
 dvbstream -c 1 -o 3000 | fedi2eti 3000 228.10.1.5 10010 | ni2out --list
using pid 3000 ip 228.10.1.5 port 10010
dvbstream v0.7.01 - (C) Dave Chapman 2001-2004
Released under the GPL.
Latest version available from http://dvbtools.sourceforge.net/
dvbstream will stop after -1 seconds (71582788 minutes)
Output to stdout
Streaming 2 streams
[04/21/24 07:16:53] Initialise next pseq to 35191
[04/21/24 07:16:53] EDI-AF: Packet sequence error
Radio fuer NRW   (0x10ec)
 0 : WDR 2 OWL        (0xd592) Pri subch=18 start=594 CUs= 54 PL=eep-3a bitrate=72 DAB+
 1 : WDR 2 RHEIN-RUHR (0xd792) Pri subch=16 start=486 CUs= 54 PL=eep-3a bitrate=72 DAB+
 2 : WDR 2 RUHRGEBIET (0xd692) Pri subch=17 start=540 CUs= 54 PL=eep-3a bitrate=72 DAB+
 3 : WDR Maus         (0xdf95) Pri subch= 2 start= 54 CUs= 48 PL=eep-3a bitrate=64 DAB+
 4 : WDRcosmo         (0xd496) Pri subch= 5 start=204 CUs= 48 PL=eep-3a bitrate=64 DAB+
 5 : 1LIVE diGGi      (0xdf91) Pri subch= 3 start=102 CUs= 54 PL=eep-3a bitrate=72 DAB+
 6 : WDR 4            (0xd394) Pri subch=14 start=360 CUs= 54 PL=eep-3a bitrate=72 DAB+
 7 : WDR 2 RHEINLAND  (0xd392) Pri subch= 7 start=288 CUs= 54 PL=eep-3a bitrate=72 DAB+
 8 : 1LIVE            (0xd391) Pri subch= 1 start=  0 CUs= 54 PL=eep-3a bitrate=72 DAB+
 9 : WDR 3            (0xd393) Pri subch=15 start=414 CUs= 72 PL=eep-3a bitrate=96 DAB+
10 : WDR 5            (0xd395) Pri subch= 4 start=156 CUs= 48 PL=eep-3a bitrate=64 DAB+
11 : WDR Event        (0xdf96) Pri subch= 6 start=252 CUs= 36 PL=eep-3a bitrate=48 DAB+
12 : WDR 2 BERG.-LAND (0xdc92) Pri subch=22 start=810 CUs= 54 PL=eep-3a bitrate=72 DAB+
13 : WDR 2 S�DWESTF   (0xdb92) Pri subch=21 start=756 CUs= 54 PL=eep-3a bitrate=72 DAB+
14 : WDR 2 M�NSTERL   (0xda92) Pri subch=20 start=702 CUs= 54 PL=eep-3a bitrate=72 DAB+
15 : WDR 2 AACHEN     (0xd492) Pri subch=19 start=648 CUs= 54 PL=eep-3a bitrate=72 DAB+
dvbstream -c 1 -o 3000 | fedi2eti 3000 228.10.2.5 10010 | ni2out --list
using pid 3000 ip 228.10.2.5 port 10010
Output to stdout
Streaming 2 streams
[04/21/24 07:18:56] Initialise next pseq to 40317
[04/21/24 07:18:56] EDI-AF: Packet sequence error
K9A              (0x10fa)
 0 : Test 6           (0xd494) Pri subch= 6 start=440 CUs= 88 PL=eep-2a bitrate=88 DAB+
 1 : Test 8           (0xda94) Pri subch= 8 start=616 CUs= 88 PL=eep-2a bitrate=88 DAB+
 2 : Test 2           (0xd692) Pri subch= 2 start= 88 CUs= 88 PL=eep-2a bitrate=88 DAB+
 3 : Test 1           (0xd392) Pri subch= 1 start=  0 CUs= 88 PL=eep-2a bitrate=88 DAB+
 4 : Test 9           (0xd694) Pri subch= 9 start=704 CUs= 88 PL=eep-2a bitrate=88 DAB+
 5 : Test 3           (0xd492) Pri subch= 3 start=176 CUs= 88 PL=eep-2a bitrate=88 DAB+
 6 : Test 4           (0xdc92) Pri subch= 4 start=264 CUs= 88 PL=eep-2a bitrate=88 DAB+
 7 : Test 7           (0xd394) Pri subch= 7 start=528 CUs= 88 PL=eep-2a bitrate=88 DAB+
 8 : Test 5           (0xda92) Pri subch= 5 start=352 CUs= 88 PL=eep-2a bitrate=88 DAB+
K9A with the Test entries is due to launch terrestrially soon with additional regional versions of WDR2 and WDR4.
Thanks, @Adam792, for the DAB identification and tests.:Y
I'm currently listening to this WDR stream and K9A in a test.
Satfaca
Melmac (46N, 14.5E)
Melmac
Hm, why am I normally getting the ensamble for 11D but not for 9A?!
It's the same WDR 11D stream on 12645 V from 23.5E
There are two streams in 228.10.1.5 and 228.10.2.5.
Satfaca
Melmac (46N, 14.5E)
Melmac
I know, that's why I am wondering why 228.10.2.5. doesn't yield any channels even if tests.
Strangely, although stream 2 WDR displays the list and images, I don't hear any sound.
I seem to be missing the right codec, although it is okay on stream one.
cirio70
Laminas 180 - Fracarro UX-TW-LTE(PLL) - C Band - TBS6903 - Octagon SF 8008 -Zgemma H92S
Lombardy - Italy
I don't think it's codec problem. The stations are mute except for "Test9" where i can hear an audio tone.
The codec used is the usual HE-AAC.
Funny that i can receive the DL+ and the Slideshow.
jsda30
edision os mio 4k
spain
Output to stdout
Streaming 2 streams
Output to stdout
Streaming 2 streams
K9A              (0x10fa)
i scanned with my octagon sf8008 but not get any channel but have good signal
any help for listem that radios?
thanks for help
EnoSat
enosat.euweb.cz
Slovakia
manual update lamedb
00c0ad54:0001:0001
    s 11604000:2200000:1:3:192:2:0
0001:00c0ad54:0001:0001:2:0:0
DAB WDR 11604 V
p:DAB,c:150bb8,f:4
update astra.conf and create userbouquet for streams from astra-sm
Adam792
Cheltenham
It seems like they’re probably just silent while they start terrestrial testing in Germany (I saw somewhere the other day that some 9A transmitters have started up). When this feed started a few months ago on 23.5°E it was carrying the actual sound of various WDR2 and WDR4 regional variations, with real service labels rather than “Test 1” etc.
Satfaca
Melmac (46N, 14.5E)
Melmac
Right, 9A used to run normally before, maybe this has to do with the network migration from 23.5E > 19.2E?!
jsda30
edision os mio 4k
spain
00c0ad54:0001:0001
DAB WDR 11604 V
p:DAB,c:150bb8,f:4
thank you
jsda30
edision os mio 4k
spain
hi! with the help of Enosat (great work) because he posted the lamedb with the specifications.
now i can listen the dab radio channels on the stream 228.10.1.5
but on the stream 228.10.2.5 i cant...
any help? im talking about 19e
thanks in advanced
andimik
Southern Austria
These are tests.
