Advice Needed Receivers with the lowest Symbol Rate?
Who has time to follow everything written on an exceptionally long topic? The time factor weighs on each of us. That's why I didn't notice what you posted over the years, thinking you were the author of many posts I thought were yours.
For that, I respected you until I discovered that you copied material from the forum to which I had many personal contributions and posted it on another forum under your nickname without mentioning the source as if it were yours.
From that moment, I discovered that what you were doing was not just an "accident" but a common practice on the forums and with the reception reports sent to FlySat.
Just because we are online doesn't mean we don't have to follow some rules, exaggerating a little, and not too much, ethics. We can overlook deviations from these rules, but when this becomes standard practice, I don't know about others, and I at least can't accept it.
You should have known that taking from others online is much easier to detect than in real life. As they say, "theft" has short legs online.
EnoSat
enosat.euweb.cz
Slovakia
Feel free to start watermarking your images so that everyone knows they are yours. Sorry if I didn't mention somewhere that they are yours. I will not mark my pictures with anything because they belong to everyone, let them use them as they see fit.
Even if the online world seems like a "jungle," we are still on a forum where unwritten rules are respected.
Even if we post under a nickname, it doesn't mean nobody is behind it.
By the way, we express ourselves and behave online, exposing our character, which is motivated, in your case, by sophistry.
That's enough for me to tell you,
Well, c'est tout alors.
Basta!
7mdish
Milan, Italy
Where can I find a good list of these very low symbol rate transponders?
Do not believe that web sites like Flysat or similar will report them? Thanks.
cirio70
Laminas 180 - Fracarro UX-TW-LTE(PLL) - C Band - TBS6903 - Octagon SF 8008 -Zgemma H92S
Lombardy - Italy
FlySat reports most of the low SR radios
most important sats to search are:
8W (around 12610 v)
23.5 E (12640 v)
21.5 E (between 11550 H and 11610 h)
16 E (11054 h and 12570 H)
10 E (12506 h)
There are more for sure but ATM i can remember that,
Ciao
Lexzie
TBS 5925 USB-tuner
The Netherlands
jsda30
edision os mio 4k
spain
For the Ustym 4K pro you need a modified LNB (not for the V9 Prime).
hi stephan sorry again for request you....
but i cant get any channel under 10730 at 26e
i got a pdf file where tell how get that channels but i dont see nothing...
you sent your lnb configuration 9363 but i dint see....
where i can see the lnb configuration for this lnb?
thanks in advanced
stephan94
Bavaria
@ jsda30
If you are using the TNAP 5.0 image for your edision MIO you have absolutely no need a special LNB. As el bandido
has already written ( post331) by using the right plugin you can indicate frequencies below 10750.
Here is the result with a conventional LNB, you can see that I get the program A71A on 10492 H 1500.
Apply exactly what we've written to you several times and it works without any problem.
finally i get a modifie lnb, this oneView attachment 155594
thanks in advanced
In what way is it modified, and where was it supplied from ?
stephan94
Bavaria
jsda30
edision os mio 4k
spain
@ jsda30
i was talking to get to my octagon sf8008
but ill try with edision os mio....
Joolz
1m Astro 55°E - 63°W
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Today for me new low SR. Alicante, sunny + clear sky.
1.8m Maraffa PF
Octagon SF8008 4K Twin......Tuner: Si2166D (DVB-S2X)
21.6ºe
11602 H 170.... DVB-S2 QPSK
Ident: 'SID 0x3e9'
SNR: 15.2dB to 16.2dB
Radio, sound heard. :Y
