Any ideas? Can it be faulty?
Did the cable come from a reputable source ?Hello,
I just bought 40m of Webro WF100 cable and i have crimped 2 connectors at the end of a portion and i get no signal going through. I then tried the other portion of the cable using 2 push connectors and still I get no signal.
Thanks!!!
By the way I changed the cable because I have a scaffolding on site.Have you checked the connections, especially the braided copper?
Have you got a satellite meter, even a basic version?
This basic one will light up, when connected to the LNB, and receiver, if the connections are working.
Has the dish moved, at all, when changing the cable? Why did you change the cable, did you lose signal, or is this a new installation?
