astra 1p 19.2e
'Go' for June 19. 40% 'Go' for June 20. Upper-Level Wind Shear risk is Low-Moderate for both days. Booster Recovery Weather risk is Moderate-High for June 19 and Low-Moderate for June 20. All other Additional Risk Criteria are Low.
A SpaceX Falcon 9 rocket will launch the SES Astra 1P mission on Thursday, June 20, 2024 at 21:35 (UTC) .
The SpaceX transmission about Astra 1P mission will begin on Thursday 20/06/2024 21:04 UTC .
SpaceX
23:18 CET Start of transmission
23:35 CET Launch !
00:10 CET Astra 1P Deployment
00:12 CET End of transmission
1 60086U 24115A 24293.76987656 -.00000130 00000+0 00000+0 0 9990
2 60086 1.3648 50.0505 1224049 193.4261 162.8419 0.95808988 1262
secret code? what s the key?
ok the path of the new Astra 1P?
Why less information about this bird??
What we have seen only some codes & numbers most of us don't understand what is going on ????
It is still in the LEOP phase, but it will not be long before it reaches geostationary orbit (it still needs a few weeks). Then they should perform tests at 9,5°W and at the end of the tests, if everything goes as planned, it will go to the final position of 19,2°E.
Those codes as you call them are the orbital elements. The current TLE for the satellite (two line element). There is nothing special about them - all satellites have tle's. So no secrets, nothing is being hidden from you.
Why less info - simple - there isnt anything to tell really.
