Well after over a year gathering bird muck and dirt I have finally decided to sort it out.
Just gave it a quick wash down.
My plan is to strip it down. Sand down, undercoat and paint the dish using the same spray paint my other dish was done with. The same treatment for the dish support on the rear.
Sand down and hammerite the feedarms and LNB holder black.
I have replacement zinc coated nuts and bolts and a brand new LNB ready to go.
The old dish is in a sorry state
I will post a picture when it's sorted.
Hopefully not in another years time
