What about tonight any news??Tonight keep ard digital hd transponder will be move 1l 1m 1n to 1p
We wait to see 1kr need move ,or 1N or 1pWhat about tonight any news??
Thx Marcus_21. From my first measurements with 3.7m I can confirm the same pointing angle for 12545 H and 12552 V (which is on 1N), that the transfer occurred to 1N. 1P is slightly more east than 1N at the moment, according to SES' official orbital data, what I have observed with my antenna.From 3:00 to 4:00 UTC, there were further transfers. I can only confirm that transponders 17 and 31 have moved to Astra 1P, while transponders 105,107,109 and 120, seem to have moved to Astra 1N... in the next few hours, I will do further checks to understand where they have moved.
Txp-17 11464 H 1N --> 1P
Txp-31 11671 H 1N --> 1P
Txp-105 12515 H 1L --> 1N or 1P ?
Txp-107 12545 H 1L --> 1N or 1P ?
Txp-109 12574 H 1L --> 1N or 1P ?
Txp-120 12729 V 1L --> 1N or 1P ?
In addition, I checked Tp 112 (12610 V) which was in 1L. It now comes from the same pointing angle as Tp 108 (12552 V) which is on 1N and definitely not from the pointing angle of Tp 89 (12188 H) which is on 1L.From 3:00 to 4:00 UTC, there were further transfers. I can only confirm that transponders 17 and 31 have moved to Astra 1P, while transponders 105,107,109 and 120, seem to have moved to Astra 1N... in the next few hours, I will do further checks to understand where they have moved.
4 to from 1n from yesterday to 1p it was free to 1l to 1N high band it come come switch soon actual 1L 14 tp activ 1 kr 3 tpIn addition, I checked Tp 112 (12610 V) which was in 1L. It now comes from the same pointing angle as Tp 108 (12552 V) which is on 1N and definitely not from the pointing angle of Tp 89 (12188 H) which is on 1L.
A few minutes ago, I did some measurements on Tp 120 and Tp 108 (1N) and observed different angles for both txps. So my conclusion is, that Tp 120 is not on 1N. Since 1P and 1L are very close at the moment, I'm not able to distinguish, whether Tp 120 switched to 1P or remained on 1L. Next chance to measure is around tomorrow morning when 1P and 1L are further apart.I still have some doubts about txp 120, even if it seems to be on 1N.
Thx, this confirms correctness of Flysat and incorrectness of Lyngsat, Kingofsat and Satindex.de for this issue.@Fortunix the transponder 112 was already on 1N.
If 1KR 1L & 1M were on the last dregs of fuel they would be running inclined by now - so there is a reasonable chance they will be deployed elsewhere. One of them may end up at 57E to allow 2A to be retired.Good satellite cleaning/Buena limpieza de satelites
15 years average life expectancy/15 años de esperanza de vida media.
...........................................Released on.
1KR 20 April................................2006 2006+15= 2021 Life expectancy expired**Using the last liters of fuel?
1L 04 May.....................................2007 2007+15= 2022 Life expectancy expired**Using the last liters of fuel?
1M 05 November....................2008 2008+15= 2023 Life expectancy expired*
1N 06 August.............................2011 2011+15= 2026 less flight to 28'2ºE (2012 London Olympics) =>19'2ºE
SES24-1P 21junio ..................2024
SES25-1Q
1KR + 1L to the satellite graveyard, 1M backup of the position?
What information do we have?
Maybe 1kr move 57eAfter doing several checks, at different times, I came to the conclusion that transponder 120 is still on Astra 1L. It is likely that the signal interruption around 4:00 UTC is due to an uplink problem or a change of ground station.
It looks all tp use pan 2 or pan 3Astra 1P Europe Wide Beam
Astra 1P Pan European Beam 1
Astra 1P Pan European Beam 2
Source: SES - Our coverage
