astra 1p 19.2e
so...does the small dish pick upanything?
I have no news on transfers regarding 1P so far.
Since 1N and 1L are notably apart from each other at the moment, I made an angular measurement on
Tp 40, 43, 7, 89, 91 & 120 against Tp 20 (1L) and Tp 108 (1N).
All of these seem to be still on 1L, even Tp 43, which has been in discussion to be on 1N.
Would this dish pick up 1P across Iberia? what about the older sats? thanks
Since the antenna is 38cm (41x38cm) if in theory and in good weather, you have to put in a good LNB.
Now with 50cm with 0.2dB Inverto Black Ultra LNB (2 outputs), the 1P signal in Madrid (Spain) is brutal (cloudy sky and some drops fall).
On average above 15.8dB up to 18dB the strongest, of the other satellites, the lowest channel 11.8dB (11817 V.- 11.8 72 88 Astra1M).
Como la antena es de 38cm (41x38cm) si en teoría y con buen tiempo, toca pone un buen LNB.
Ahora con 50cm con LNB Inverto Black Ultra de 0'2dB (de 2 salidas), la señal de 1P en Madrid (España) es brutal (cielo nublado y caen algunas gotas).
De media por encima de 15.8dB hasta 18dB el mas fuerte, de los otros satélites, el canal mas bajo 11.8dB (11817 V.- 11.8 72 88 Astra1M).
thank you. by brutal you mean the signal is very strong?
Do you think this dish would pick up 1N in Madrid on a clear day?
Not so far. Best I have got is 4.5dB on 11464H but no lock. I'm using a rather crude method of just holding the dish in my hand out of the window so fine tuning is not really possible. I can get the Astra 2 UK beam at about 8.5dB locked though, so maybe that is swamping the signal.
Today there was no transfer, everything remained as yesterday.
I attach a pdf file, updated with all the changes and the distribution of the txp on the various satellites.
Fruit of the results of the detections, carried out during the hours, that the various satellites distanced themselves from each other.
Do we know if channels on Astra 1M will also join Astra 1P?
