dreamsat
- 2,20m Kathrein, 3,7m Andrew, KU,KA,C,C-Ext. LNBs
- germany
hi which tbs card u advice at 2025? for full blindscan fastest and without any problems on windows10/11?Totally unexpectedly strong is the signal on three transponders at 78.5E on Thaicom 8: 11152 H,11155 H,11185 H.
My recommendation in 2025 for a dvb-s2 card was and still is tbs6903, and for the S2X extension, 6903x/6909x if you are an enthusiast.hi which tbs card u advice at 2025? for full blindscan fastest and without any problems on windows10/11?
thx too much sir. but no problem for me about delay time but if not more than 15 min. so example if 1+ hours has for search then its bad of coruse? btw im enthusiast and more deep enthusiastMy recommendation in 2025 for a dvb-s2 card was and still is tbs6903, and for the S2X extension, 6903x/6909x if you are an enthusiast.
I say this because the difference between an amateur and an enthusiast would be that the former is looking for more TV/Radio programs, while the latter for more muxes.
However, some users are reluctant to use these cards on Windows, mainly because of the slow scanning.
There may be other objections, depending on what the buyers want.
I have oversimplified the options available to users when choosing a card that works for them.
sir really thx for infos really thxFor enthusiasts like you, the first thing to know when choosing a card is to see if it has full or partial Crazyscan support.
The TBS6903 has full support, and it moves fast, depending on the steps the user sets.
