7°E Eutelsat 7
  • Thread starter Thread starter Anonymous_1
  • Start date Start date
Not as strong for me as usual. Signal fluctuates a lot.
Those of you with bigger dishes than mine might like to check 7E for Ka band signals. Nothing found here. I think my LNB may have failed. It was an Inverto dual band one.
i think you hav a Problem
Thanks Dreamsat. Just had a go with another RX and all good now. It was not switching polarity but is now. Thanks for checking/
The three transponders (dreamsat #524) are still active.
21533 H is a very weak signal in QPSK.
Die drei Transponder (dreamsat #524) sind nach wie vor aktiv.
21533 H ist ein sehr schwaches Signal in QPSK.
my scan with VMA Streamreader
There's a football feed up:- 21662H 7200 Uganda v Senegal enc
Angola football feed today on 21671H 7200 S2 8psk 3/4 FTA. Another much weaker feed on 21662H-no lock here.
Here's 21633 H with a pic
Anything new?
No new feed frequencies noted recently by me but over the previous last three to four days or so it has been busy, sometimes three transponders up at the same time on the known listings
Yes they will be back tomorrow for world cup qualifiers !
And away we go ..... two up at the moment
21.663H , 21.681H
21.672 H
Screenshot 2025-10-13 16-36-39.webpScreenshot 2025-10-13 16-38-27.webpScreenshot 2025-10-13 16-57-39.webpScreenshot 2025-10-13 16-59-20.webp
i can two transponder receive
Hi in order to receive those feeds at 7east with my gt combo which lnb i have to put? 20000+
At the moment i have inverto ultra flange with invacom feedhorn.
two feeds today
New feed, 21661H.
First check with the TBS5580. Windows only, not working in neumodvb.
Also, first use of XMW Ka LNB since drying out after interrnal soaking (rain entry when cap fell off). I thought it was bricked at one stage.
