deeptho
- Wavefrontier T90, Laminas 120cm, 2 other dishes; tbs 5927, tbs6904, tbs6909x, tbs6903x, tbs5990, tbs6981,tbs5927
- Europe
My advice: You should do that, and you should also allow this to be combined with committed mode, usals, diseqc1.1 and in any order.So tell me: should I add an uncommitted mode that just outputs F0 to FF for ports 1-16?
How do common receivers manage all these differences?
This is needed for people using many lnbs: e.g., you can comvine 1 committed 4x1 switch with 4 uncommitted 4x1 ones, or vice versa to
address 16 lnbs. You can also combine 1 committed 4x1 switch with 4 16x1 uncommitted switch to address up to 64LNBs (a bit overkill of course,
unless if you also switch between multiple dishes. It is also possibkle to combine this with diseqc1.2 and with usals. For example: a moving
dish can be combined with a switch (there are limits related to power consumption, but one rotor and one switch does work).
In all of this, it is important to send messages in the right order, wait long enough for voltage changes to be completed etc.
diseqc2.x are supported by many switches and also needed to configure (but not use) Jess, unicable and such.
In theory Jess, Unicable and such are multually exclusive with diseqc, but in reality they can be combined with that as well.
