The free AFN channel “Bars and Tone” has been a black screen since today.
zorrin
Specialised contributor
CM 120 Ku 52°E to 45°O
CM 120 Ku 50°E to 45°O
CM 120 Ku SDR 25.8°E
CM 100 Ku 5°W
CM 100 Ku 9°E
CM 90 Ku
Visiosat Bisat Ku
Visiosat 70 Ku
Selfsat 2x Ku
Selfsat 2x Ku
Octagon SF8008
GTMedia V8 Nova, V8X, V8 UHD 4K, V9 Prime
Edision Piccollo
france
I watched this channel yesterday and it was still there, and today it’s a black screen.
It seems that the entire AFN package has changed today…
Use this thread to tell, that AFN will stop its frequency on 9E satellite some time today. They are going online only, leaving just 4 poor quality SD-channels available on C-band on 57E satellite. Also abandoning PowerVU as friendly global forum said, so again one provider less to watch using good old key technique.
Must be this mentioned a while ago.
They are gone
EutelSat 9E Ku And 57E C-Band AFN Network Security Change, Even Not Opening on iks Forever Server
signal still there but no picture
I wonder if any of you with larger dishes have checked the AFN signal on 4124L 34.5W? On my HD Ranger I see a signal but no lock?
Eventually I managed to lock the AFN mux at 34.5W and nothing has changed here.
@EnoSat How large is your dish if you have a 12 dB signal on 57°E? Is the signal stronger on 34.5°W?
Thank you very much.
I get around 8.5dB on AFN with my 1.8 Channel Master in the UK on 34W.
“AFN Network TV channels are no longer available on 9°E, but they continue to broadcast on 57°E C-band and are working with PowerVu keys
9E/11804.20 V is off. The AFN Atlantic Radio package has been moved to 11900.10 H, as indicated in the NIT following the discontinuation of TV services
