RAI DAB+ feed from 5 West
That's an interesting report...
Which 14 stations are affected?
All 14 sites in Aosta and in the western part of Lombardia, which use channel 8B (the eastern part uses 7C in a very large SFN) will get this new mux with (2) local variants of RAI Radio Uno.
So RAI will have two local and one national mux.
Well, let’s see what July brings – whether there’s any news on the satellite front.
RaiWays, however, handles the bulk of its traffic via land bridges
Someone reported that the DAB BuMux on 12168 V at 23.5E has stopped broadcasting. I checked the mux and found that the two DAB stations are still active.
Who knows, maybe they’ll leave on July 1(?).
forget that, it was an error, and the person has deleted it.
But good news, I found two additional muxes on 5W!
While looking for possible new RAI transmission for Aosta Valley and Piedmont West, I found MEDIADAB 6D from Liguria (Genova) on 5°W:
It's on the same TP like the RAI national DAB multiplex, but on a new MIS 21 and they are using the same technology like RAI
PID is 1002
ts2na -p 1002 -s 0 | na2ni | ni2out --list
FICDecoder: SId 0x5171: programme service label 'GIORNALE RADIO' ('GIORNALE')
FICDecoder: SId 0x5A83: programme service label '.SYSTEM.' ('.SYSTEM.')
FICDecoder: SId 0x5263: programme service label 'R Buon Consiglio' ('RBC')
FICDecoder: SId 0x5982: programme service label 'RADIO A' ('RADIO A')
FICDecoder: SId 0x5223: programme service label 'RADIO ROCK' ('ROCK')
FICDecoder: SId 0x501D: programme service label '70-80.it' ('70-80.it')
FICDecoder: SId 0x5FE6: programme service label 'RADIO SUNBEAT' ('SUNBEAT')
FICDecoder: SId 0x5E5E: programme service label 'Radio104' ('Radio104')
FICDecoder: SId 0x524D: programme service label ''R.BRUNO' (''R.BRUNO')
FICDecoder: SId 0x529E: programme service label 'MC2' ('MC2')
FICDecoder: SId 0x53B0: programme service label 'ROMANTICA RADIO' ('ROMANTCA')
FICDecoder: SId 0x5249: programme service label 'LIFEGATE' ('LIFEGATE')
FICDecoder: SId 0x50F1: programme service label 'RVS' ('RVS')
FICDecoder: SId 0x3D44: programme service label '#DANCE' ('#DANCE')
FICDecoder: SId 0x529C: programme service label 'Q8 Radio' ('Q8 Radio')
FICDecoder: SId 0x5B65: programme service label 'MANILA' ('MANILA')
FICDecoder: SId 0x5009: programme service label '3NGINE RADIO' ('3NGINE')
FICDecoder: SId 0x5212: programme service label 'CUSANO' ('CUSANO')
FICDecoder: SId 0x5FE7: programme service label 'RADIO 906' ('RADIO906')
FICDecoder: SId 0x5175: programme service label 'GR NEWS' ('GR NEWS')
FICDecoder: SId 0x52D1: programme service label 'Parole di Vita' ('ParVita')
FICDecoder: SId 0x530A: programme service label 'RADIO SM' ('RADIO SM')
FICDecoder: SId 0x9880: programme service label 'RADIO SANREMO' ('SANREMO')
FICDecoder: EId 0x5050: ensemble label 'MEDIADAB' ('MEDIADAB')
It was a bit tricky as all MEDIADAB ensembles have the same label, but 0x5050 is channel 6D in Liguria.
And I found the new local RAI mux, which will start on 1st July only.
As announced by RAI it really contains all 20 (!) labels for the regional versions of RAI Radio 1, but all other then Aosta and Piedmont are pointing to the same subchannel. Therefore, the bitrates are still quite high for Italy.
ts2na -p 1001 -s 0 | na2ni | ni2out --list
INFO: Using pid: 0x03e9 (1001)
WARN: Forward error correction (FEC) disabled (NOT COMPILED)
INFO: E1 Sync found at bit: 64, inverted: no
DEBUG: seek: B:8, b:0
DEBUG: pre-readed output 15 frames (23 bytes left):
DEBUG: MULTIFRAME FILLING: 207
INFO: ETI Sync found at pos: 4
INFO: ETI Multiframe sync found at blockId: 18
.DAB+ RAI Test (0x5dab)
0 : Rai Radio1 CAM (0x526e) Pri subch=12 start=720 CUs= 72 PL=eep-3a bitrate=96 DAB+
1 : RaiR Live Napoli (0x52f2) Pri subch= 9 start=522 CUs= 66 PL=eep-3a bitrate=88 DAB+
2 : Rai Radio1 ABR (0x528e) Pri subch=12 start=720 CUs= 72 PL=eep-3a bitrate=96 DAB+
3 : Rai Radio1 SIC (0x52af) Pri subch=12 start=720 CUs= 72 PL=eep-3a bitrate=96 DAB+
4 : No Name Radio (0x520a) Pri subch=11 start=654 CUs= 66 PL=eep-3a bitrate=88 DAB+
5 : Rai Radio1 TOS (0x527f) Pri subch=12 start=720 CUs= 72 PL=eep-3a bitrate=96 DAB+
6 : RaiTuttaItaliana (0x5207) Pri subch= 5 start=264 CUs= 66 PL=eep-3a bitrate=88 DAB+
7 : Rai Radio1 MOL (0x52bf) Pri subch=12 start=720 CUs= 72 PL=eep-3a bitrate=96 DAB+
8 : Rai R Classica (0x5205) Pri subch= 6 start=330 CUs= 78 PL=eep-3a bitrate=104 DAB+
9 : Rai Radio1 Sport (0x520f) Pri subch= 7 start=408 CUs= 48 PL=eep-3a bitrate=64 DAB+
10 : Rai Radio1 VEN (0x52de) Pri subch=12 start=720 CUs= 72 PL=eep-3a bitrate=96 DAB+
11 : Rai Radio1 LOM (0x52fc) Pri subch=12 start=720 CUs= 72 PL=eep-3a bitrate=96 DAB+
12 : Rai Radio Kids (0x52f3) Pri subch=10 start=588 CUs= 66 PL=eep-3a bitrate=88 DAB+
13 : Rai Radio1 PIE (0x523f) Pri subch=12 start=720 CUs= 72 PL=eep-3a bitrate=96 DAB+
14 : Rai Radio1 VDA (0x523e) Pri subch=13 start=792 CUs= 72 PL=eep-3a bitrate=96 DAB+
15 : Rai R Techete' (0x52f1) Pri subch= 8 start=456 CUs= 66 PL=eep-3a bitrate=88 DAB+
16 : Rai Isoradio (0x5209) Pri subch= 4 start=198 CUs= 66 PL=eep-3a bitrate=88 DAB+
17 : Rai GrParlamento (0x5206) Pri subch= 3 start=156 CUs= 42 PL=eep-3a bitrate=56 DAB+
18 : Rai Radio1 PUG (0x52cf) Pri subch=12 start=720 CUs= 72 PL=eep-3a bitrate=96 DAB+
19 : Rai Radio1 LIG (0x526f) Pri subch=12 start=720 CUs= 72 PL=eep-3a bitrate=96 DAB+
20 : Rai Radio1 SAR (0x525f) Pri subch=12 start=720 CUs= 72 PL=eep-3a bitrate=96 DAB+
21 : Rai Radio1 MAR (0x524f) Pri subch=12 start=720 CUs= 72 PL=eep-3a bitrate=96 DAB+
22 : Rai Radio1 TAA (0x5401) Pri subch=12 start=720 CUs= 72 PL=eep-3a bitrate=96 DAB+
23 : Rai Radio1 FVG (0x52ce) Pri subch=12 start=720 CUs= 72 PL=eep-3a bitrate=96 DAB+
24 : Rai Radio1 EMR (0x52ee) Pri subch=12 start=720 CUs= 72 PL=eep-3a bitrate=96 DAB+
25 : Rai Radio1 CAL (0x52fd) Pri subch=12 start=720 CUs= 72 PL=eep-3a bitrate=96 DAB+
26 : Rai Radio2 (0x5202) Pri subch= 1 start= 0 CUs= 78 PL=eep-3a bitrate=104 DAB+
27 : Rai Radio1 UMB (0x527e) Pri subch=12 start=720 CUs= 72 PL=eep-3a bitrate=96 DAB+
28 : Rai Radio3 (0x5203) Pri subch= 2 start= 78 CUs= 78 PL=eep-3a bitrate=104 DAB+
29 : Rai Radio1 BAS (0x521e) Pri subch=12 start=720 CUs= 72 PL=eep-3a bitrate=96 DAB+
30 : Rai Radio1 LAZ (0x5201) Pri subch=12 start=720 CUs= 72 PL=eep-3a bitrate=96 DAB+
I found this by chance on digitalbitrate :-)
In addition to MIS 11 and 12 on 12562 V, 35300, 3/4, 8PSK, we now have MIS 21-Media DAB, and on MIS 12, the DC-II Video stream
Videostream????? Very funny. This is DAB digital radio.
Haven't you read my posting? Internal Tests for RAI. They will officially start on 1st July.
I tested MIS 21 on 12563 V, 35300, 3/4, 8PSK for DAB Media, and it runs very well.
Thanks to @andimik for his efforts in searching for and finding these DAB streams. :-clap
It turns out that the much-anticipated expanded DAB RAI service(test) announced by @andimik(thanks) is now up and running and can be listened to.
It's on MIS 12.
Both Italian DAB RAI and Media with MIS 12 and 21 on 12563 V work well on Windows with Crazyscan and WSL_Ubuntu 24.04
Has anyone tested the RAI Test ensemble 24/7?
I just want to know if eti-tools still have a problem with the reconfiguration during local news.
I can't receive BBC anymore, so I have no idea if it persists.
If yes: Maybe I try to fix it with AI.
Are you referring to the RAI Test on MIS 12 or MIS 21 MediaDAB at 5.0W? If so, both DAB stations are working fine. Of course, the same goes for MIS 11.
Which BBC station are you talking about, on 12092 H at 9.0E?
Yes, the RAI Test Mux
Have you tested during the switch to local configuration and back to national?
There is no BBC on 9E. They are on the UK Beam on 28.2E
Both are the only NA muxes via satellite with reconfiguration.
I didn’t test it when it was switched over, but only just now, when I read your message yesterday.
But eti-tools are always working , when you are (fresh) tuning. I'm talking about reconfiguration.
When I tested eti-tools, I didn’t notice anything unusual in its behaviour or any desynchronisation. It quickly identified the IDs and played the stream without any interruptions. That’s why I was surprised that, with a signal that wasn’t exactly strong – 7.8 dB – I had no problems playing the stream.
Perhaps it would have been better to test the RAI DAB MISs on 1 July or immediately afterwards. The result and diagnosis would have been more conclusive(?).
Ok, I'll try again to ask if anyone has seen problems with eti-tools during reconfiguration (when subchannels change, etc)?
I can't receive the UK Beam for BBC here in Central Europe and need to re-adjust my dish for 5W.
Similar to
But this was done with a terrestrial signal.
I doubt eti-tools work with reconfiguration, but please share your impressions.
