Some Tps no signal 13E
n.u.k
Octagon Sx88 4k UHD s2.Vu+ zero HD. Dish 8FT SHABBIR A CLASS. Dish 4FT. Dish 2FT. ptcl charji evo 4g. Zong Bolt 4g
pakistan
Hello
I have TPs 11488 11585 10719, the signal is there at night and the signal becomes 0 during the day. What is this problem? Please confirm?
There are some other TPs. 11373 10930 11900 12284
Hello
I changed the LNB and the problem is solved.
¿From what make and spec type of lnb did you change from and replace it with? Thanks. Glad you sorted it. :Y
The LNB on which I spent more money was showing this problem. It is a premium LNB which costs 900 Pakistani rupees.
And everything is OK on a low-cost LNB which costs 200 Pakistani rupees. I am surprised.
Thanks for the reply.
900 Pk rupees is 3£ ...so 200Rp is a good price!!
You must be using the 8ft dish for this I guess? Most of Pakistan is out of footprint for Hotbird.
Yes: I am using an 8ft dish. On a very hot day the signal of some frequencies becomes weak.
