Ragnarok
- Sky Q DSCR multi switch setup
VU+ Solo 4k , Octagon SF8008 Suprime V2, Primesat PR1000 Vbox , Skyscan jack , channel Master 1.2m dish , Golden Media Dual LNB.
- UK
I Personally Found the older Golden Media 202+ models ( dual LNB ) to be the best performing on my Channel Master 1.2. It crushed my inverto's black ultras and kept the peak performance for longer. Also for some bizarre reason the brand new 202+ dual LNB's where actually better than the Single 201+ on marginal signals for me. up and sown the band I had better locks on all sorts of weak signals and partial lock on stuff i hadn't haden before.
I always had to buy them from Germany. Looks like the ones that I found that worked great 4 years ago have changed and i have no idea if the newer smaller models are any better or worse.
I suspect we are entering the enshitification phase it's going to be trial and error to figure out who is making the best LNB's. Also in this space old stock also tends to have an expiry date where the performance drops off.
