Adding declination control (Fibo 90)
Just a mock up at the minute, built from stuff I had laying around. No actuator yet either. A DARL 3608 or 3610 should be good.
Before:
Parts:
In situ:
snibble
fibo 90dish+inverto white
spiderbox + 80 cm motorished
s e england
that looks exactly like what I would like to do if only I had the rear mount!!! I have the polar mount but can't find a supplier either of original or mod - am trying to make one meantime but any info anyone has would be very welcome indeed
Can you post a picture of your mount?
If you want a fixed mount you can probably get one here (just send an email to them telling them what you need):
_http://www.satmueller.de/englisch/produktframe.htm
wod
yorkshire
is the actuator going to be fitted at the bottom to push the dish out to make it point up when needed ?
fergyc
VU+ Duo with ViX and OSCAM, Prof Revolution 7301 PCI Card, 2x Dreambox 500S, 80cm Technomate Dish with Inverto Black Ultra and TM-2600 DiSEqC Motor. Technomate TM-300D along with a few zone 1 minidishes that get moved regularly and a zone 2 for 19e a
Northumberland
Bit off topic but is there anything other than an actuator you could use?
snibble
s e england
huevos
have emailed germany and await reply - its just a standard fibo 90 cm rear mount- if anyone knows of a uk source new or used i am very interested- apologies for slightly off topic but thanks for help
Yes. It will push the 2 arms apart. Geometry is such that the actuator is at 90º as it crosses the arc. Dish starts more than 10º below the arc, and goes up plenty more above it. There's no play and the action is as smooth as silk.
snibble
s e england
Hi Huevos
this is what I need- new or used uk or europe am emailing germany
Why re-invent the wheel? A 3608 is only 19€.
fergyc
Northumberland
Just thought it would be good to make something myself so there's nothing else like it
snibble said:
Hi Huevos
Lets see how you get on, otherwise you'll have to make something from scratch. Probably easier than it first appears.
snibble
s e england
I have some brackets that might fit but will need re drilling- lets see how we get on...
Trust
Nijmegen Netherlands
Trust1 said:
[[Just thought it would be good to make something myself so there's nothing else like it ]]
I like that spirit !!
complete rebuild SG2500 with elevation
Picture looks good. Link doesn't work.
Trust
Huevos , I build it for feedhunter Snuffer , just made a test on stable sats .
But even when you think your alignment is OK , there is always that little doubt-devil who makes you think , maybe a little bit up or down give me a better signal .
Therefore i have also a elevation actuator on my 120 Fibo
I got an actuator with an 8 inch stroke (smallest I could find) but it was still too long so I've had to cut a piece off it.
Here's what it looks like when it's altogether and on the arc. Hardware limits set 11º above and below the arc.
Hakon
My setup
Laminas180cm P.M 60e-30w
24" SuperJack,Clark-Tech V-Box
Laminas120cm CM P.M 75e-30w
18" Superjack, Clark-Tech V-Box
Gibertini XP premium 100cm
Polar Mount, 12" Superjack
75e-30w
2 x Vu+ Duo
Sweden south
