If they would produce toroidal antenna equivalent to 120cm (as it was announced more than 10 years ago), that would be much better solution than T90, not even speaking about T55. I also consider my T90 as an object to play with. T90 still can give possibility of simple (usual) watching TV for majority of channels people watching, also good good family. That is why I do not understand you Hacon why you dismounted T90 and throw it away from your setup!
I will try to always keep my T90 up and running, cuz it is my first antenna and it is just great. But, at the same time, now I like to have motorized antennas, I like to tune them and also hunt for weak signals. Cband is another field I would like to explore. And because of having triple sat-tuner + terrestrial, every stationary LNB and some motorized antennas with several LNBs (C and Ku), and terrestrial will be connected to one system. It is actually already now like this, but only not fully operational capable. By prioritizing 3 SAT tuners it is possible to have weak signals from big antennas, and strong signals from stationary, including T90.
