sky italy card + dm7020hd
Big-Apple
2x Dm800
1xDm7000
CEE
i know owner of few sky italy cards he was using also skydigiboxes
as we know all sky italy card 093b are done but he sended me mail that 09cd card also same killing ecm error but not 0994 point is
he probalby didnt used blocked maybe he dont admit bloker LOL what bout 919 id card is that card safe?
and most important dm7020HD can we put 9cd inside slot or it will be again burned?
sonic1
Vu + Ultimo 4K - Solo 4K - Uno 4K - Duo2- SoloSE - Zero- Uno -Prismcube Open Black Hole - 0.6 , 98cm Funkee , 28E-23.5E-19E-13E
Black Hole Team
The only emu to use is oscam and you must use blockers.
Updating the card must be in an original box.
Internal readers are never the best option, omnikey or smargo is a better option.
0919 are very few and far between theses days.
Big-Apple
2x Dm800
1xDm7000
CEE
so u wana tell me that for now doesnt matter if this is 919 93b 9cd any new subscriber which wana use this card must order with skydigibox to update card and use oscam with all block? as i remember cccam is properly working/recognizing card 919 and also updating as only card 093b and 09cd arent.
sonic1
Black Hole Team
If you want a method which is likely to keep the card alive then yes full blocking and updates in an original box is the safest method but again the card can be killed off in an original box if the provider so wishes.
The problem with CCcam is people us an old cfg with the later versions of CCcam and are unaware they are allowing global emms
# control how to deal with global (ga) EMM readers (clientside setting)
# can avoid global (possibly noisy) emm being sent over the network
# shared and unique emm is not affected by this setting
# to block all emm, use DISABLE EMM setting instead
# 0 = ignore all global emm
# 1 = accept a small amount of global emm
# 2 = accept all global emm
#[color=#ff0000] default: 2 (handle all global emm)[/color]
# example: seriously reduce the global emm traffic, but allow limited
# global emm when a smartcard does not work (possibly because it needs an update)
GLOBAL EMM : 0
You will see plenty of original sky it box's on ebay and the like these days because of this very reason.
Big-Apple
2x Dm800
1xDm7000
CEE
just asking :) worst thing u never know when update appears instead of others systems
