Astra 2F at 28E (at last!)
Is 10958H a 1N frequency? I can't see it on the LyngSat list for Astra 1N. Just scanned it and am receiving 5 USA, 5*, Channel 5+1,etc.
You are still locking the 10964 Transponder >>>>> Each TP is around 20MHz wide so if you target a frequency a few MHz away from nominal, then you will merely lock the nominal..................
There have been no changes as yet.
Come on, chaps - 18 Registered Members reading this Thread and nobody wants to say hello?
Hangs head sheepishly.. I feel I've been ticked off....
Erm... Hello?
Sorry - I'm one of those non-technical readers waiting for gems of wisdom from those with "the kit" and hoping I keep a decent signal in Barcelona.
I know that it has nothing to do with 2F, but I observed 1N signal increase recently. Frequencies which have always been almost unreachable e.g. 11127, now showing almost around the clock
Erm... Hello?
Yes, a tricky area where you are: I see you are using an 80cm for now and even a little further South or East bigger is already de rigeur.
Waiting for 2F is like being a chelsea manager.... you know what is coming, just a question of when....
I can remember a summer in the 80s when the England cricket team went through 4 or 5 different captains. They didn't win much!
Good morning, and ditto :-) The only "kit" I have is a Humax Foxsat PVR and a non-steerable 80cm dish. Astra 2D was fine here (except a few transponders in bad weather), so I eagerly await 2F! 1N has been receivable here on 53cm dishes with cheap LNBs. Location: Bergen, Norway.
Possible switch-over on transponder 11024H (BBC HD Scotland and Wales test). Signal level changed about 15 minutes ago. About 4dB down on this morning.
Spectrum with yesterday's outline superimposed.
After reviewing the last reports I'd say nothing has been switched yet. Maybe a single transponder (10964H) has changed -> #156 @avionista, #166 @solly
/edit
have to check on 11024H -> #190 @Huevos ;)
possible, it's +0.5dB here
I see we have newly Registered Members popping up on here now, so may I welcome you all to the Forum and hope we can tempt you to stay even after the current excitement is over! :-1welcome
ill check it see if there a difference here as well, might not be much but might help identify if it has changed
edit
quite considerable change it snr 98% agc 84% and that is in this mosoon rain central scotland is getting
148 cbs action NO SATELLITE SIGNAL
146 CBS REALITY NO SATELLITE SIGNAL
149 CBS DRAMA no SATELLITE SIGNAL -this was DEF still there when the above two went
321 TRUE MOVIES - NSS
322 TRUE MOVIES2 - NSS
502 BLOOMBERG NSS
508 EURONEWS very broken up
505 cnbc nss
lost everything on superbeam E28A
went off 1.54 CET
clear blue sky now (23c) channels are back
edit
Just a normal day for you then !! O-grab
well mostly ;) generally dnt get a months rain within a few hours ;) but yeah rain is pretty normal for us so is 4 seasons in a day ;)
11024 H is unchanged here at 14.5 dB both yesterday and today.
