Astra 2F at 28E (at last!)
Where exactly ?
Well south of Alicante is Alicante-Torrevieja. If a 1m dish is not working there it is because it is not installed properly (like most of them).
Would you expect a 1m high gain dish to be able to get a picture in San Miguel de Salinas?
It might do, we have only had 4 reports from round Torrevieja so far, and 110 is the smallest success so far.
I tried, but I only have a satcatcher meter that doesn't support dvb-s2 and a sky box, so I don't think I can try anything at this stage....
Here in Lower Normandy, France 11023 H is 99% SNR on a TD88 using a Vu+ Solo.....in heavy rain. Appears no different to transponders from 1N....
"a 85cm satellite dish in Gandia is receiving this Astra 2F test signal" i would be interested in more information about this report as i am not convinced that this is based on a stable reception report !
@SonnetPete: Yes, but isn't Normandy part of England - or did I do my Bayeux Tapestry trip back to front?
Yes it is stable and it is a motorised dish with the LNB skewed for the arc (not -7.5º). Dish belongs to Woborny. And I get it here, 100km further south, on the Fibo 90.
@Torrevieja, what satcatcher meter have you got? Doesn't matter that it is DVB-S only. Check BBC2 England transponder (10773H). If the dish is set up right you should have at least 8.8dB C/N on a Satcatcher.
just noticed since 30min ago a sudden drop of 10% from the signal ..been using a fixed very well set channel master 1.80 since yesterday to monitor the situation
Thats the map updated to sonnetpetes report. Think that will have to do for tonight - Im going x eyed staring at the coloured blobs!
Well I never did get the wee Dram I asked you to Fax me last night.
No change here - still on the stops at 99%, although its cold & clear here atm
So is it an 80 cm dish then or was that another report ?
its also clear where i´m right now (Javea area )
11023H
got a picture - but breaks up on 8901 & 8911
100% stable here on the 90cm and the same SNR as last night. In the days of 2D this would have been considered excellent daytime signal on a 1.8m dish.
And the LNB is skewed for the arc on this dish, not Astra.
Right now on the 90cm 7.7dB; on the LH110 8.6dB; and on the 1.8m 12.4dB; using the Emitor Color HD.
