Astra 2F at 28E (at last!)
g8vkv
1m dih Humax Foxsat HDR
Draguignan, France
That is very weird.
Is everyone of the opinion the beam has been moving?
Something's happening here (Draguignan, France).
23rd - 11023H signal suddenly lost at 13:30, before that SQ 75/60 on Humax Foxsat HDR with 90cm
24th - 11023H SQ same up until 16:00, then lost suddenly
today 11023H SQ same, still OK at 17:00
all times CET
Now breaking up at 17:30
joddle
Massanassa, Valencia, Spain
When the swap does eventually happen - will we need to adjust our dishes?. I note on some forums a few people are talking about tweeking their skew and the dish itself. Does this mean the new sat will be in a slightly different place and have a different skew? and if it does is this why some people can't get a lock on the new signals at the moment? I hate change ......
zeeteefje
et9k, T55, 1 meter on rotor
France
It means their setup was not brilliant, but the strong signal was camouflaging that
deepbluesky
Terratec T-Stick+ (DAB+)
Stuttgart (48.79N/9.19E)
on the germany site sattuloger had the same problam and he fix it , no signal , can you check with reciver??
your cart is tbs?
vladan, he's just a bit too North and East so outside of the very sharp edged beam. Here are his location and system details:
Schöningen (Niedersachsen) - 52,13°N - 10,95°O
Equipment: Gibertini OP 100 XP mit Inverto Black Ultra (Quad) und GTSat GT-DM14MG (45°W - 70.5°E)
Vantage HD8000S / Technotrend connect S2-3600
sattuloge's dish is 3.65m, so not comparable to that of gonzobaby. His location is at least 150km SE.
Pesky Kids
Lenson Heath 120cm offset Dish
Black Ultra quad lnb feeding...
- Sky+ HD Box
- Foxsat HD Freesat box
- Humax Fox F1 FTA box
Maranello, NE Italy.
That is very weird.
weird is one word. I prefer to use gutting.
If it transpires, once all this movement has settled down that I am without 2F, then I'll be gutted knowing that I am in the physical footprint but they have electronically (by steering the beam or otherwise) managed to stop me receiving it.
DishDick
Gran Canaria
Joddle, all these satellites can not be in the exact same position if they were it would mean they had crashed into each other! They are very close (but not touching), it is possible with a large dish to optimise the signal of one satellite by aligning the dish to transponders on that satellite (as we did with 2D). This means (unless we use more than one dish - some bars have two 3m dishes) we won´t get all the channels that we could get, but we get the channels we want the most.
Torrevieja
FAMAVAL 1.4m High Gain
Torrevieja, Spain
No change here today in San Miguel De Salinas, (Torrevieja).
Dish: 1m*
LNB: Black Ultra Twin
Cable Run: 10m shotgun triax
Receiver: Ferguson 102E
Result: Locked, completely watchable, pixilation at random times
* Dish marketed & sold as 1m, actual measurements are more like 100 x 90
bonou2
strong 4500, openbox X801, vantage 7100ts, vantage X201 CI, goldenmedia 9080,goldenmedia uni-box2,tbs6925+,inverto black ultra+C120,panorama er-861, zinwell lnb 15K C- band,intersat 20K
madrid south
135*120 cm fixed
offset dish oval
lnb inverto black ultra
golden media uni-box2 ---- L=89% ,Q=18-36% signal fluctuates
the signal audio-video is stable :-righton
amiko alien 8900hd--- L=78% ,Q=70%
davidcmadrid
40cm offset 19e, 1.5m 28e 1.2 M motor vu+
Madrid Spain
madrid south
135*120 cm fixed
offset dish oval
Thanks ! There is hope for me here in Goya :) What is the amiko alien , a type of tuner ? Sorry not able to distinguish the substantial difference between the two reports.
In any case , this is the most westerly report in the Spanish " edge " to the beam since there has been talk of the beam " moving / shifting " eastwards so either the eastern edge has expanded towards eastern europe or its a different beam being tested since this south western edge seems " solid ".
1.0M no reception
Where did you get that report? Yesterday I popped down to see "Torrevieja" and adjusted the dish. 1m Famaval Hi Gain (which is really a 90cm dish left/right) produced a watchable picture with occasional pixeling.
zeeteefje
France
No, you are not able to do that. The distance between satellites is around 0.01 degrees. The opening angle of a 3 meter dish is about 0.6 degrees. Way to big to notice any difference between satellites.
bonou2
satellite receiver amiko alien 8900hd use two operating system spark and enigma2
in my report i use spark firmware 1.2.54
golden media uni-box2 i use firmware 1.4.79 sp
joddle
Thanks for that- of course I realised they were not close to touching each other but had wondered about their orientation - ie if the amount of skew could vary slighlty from one to another of the sats. If most of what I want is going to be on 2F then it would make sense to optimise for that sat!! And is the EPG still going to be on another Sat for freeview? SORRY I MEANT FREESAT :-wow
@Joddle: Freesat (Freeview is UK DTT!) EPG will remain on Eurobird (As I still call it - We don't like change!).
DishDick
Gran Canaria
Joddle I will wait until it all settles down. 2F might move slightly when 1N and possibly 2D move from 28.2.
buckshee
Placemark 83 on map
100km North of Munich., Germany 1 metre dish snr 45%, picture OK but occasional pixilation - normal is 79%
Ive put your pin in as Eschelbach in the map - is that close enough?
That's not true. The satellites at 28.2 are often 0.2º apart. Also, E28A and Astra 2 are 0.3º and that can easily be seen on a meter even when the dish is only an 80cm.
Satellite74
80cm oval dish, Invacom single LNB prime focus 28.2°E, generic quattro LNB secondary focus 19.2°E; Technisat SD receiver
Hanover, Germany
and in which direction do you suppose it might move? And will that affect the footprint any?
C0re
Specialist contributor
Ede
VU+ Solo SE
Gelderland, The Netherlands
The 2D has already moved to 28.0 (check Lyngsat or KingOfSat).
