Mounting Raspberry Pi to Dreambox 5620s
adam watson
80cm dish, quattrro and m/s for 28.2, singles for 19.2 and 23.5. Sky HD and Fortec Star Passion HD
Berkshire, UK
I've got a Raspberry Pi running Arch linux and Samba with an external drive. I have managed to map the drive to a Windows PC but I can't get it to mount to my Dreambox. The Dreambox is a 5620s running Pli image from a few days ago. I've tried using the web interface, through the menus and via the command line.
Is there a log file somewhere so I can get an idea of why its failing?
Can anyone give me an idiots guide as what to put in the fields on the web interface I'm not sure of the server path?
Any help would be great
Adam
How is the hard drive connected to the Pi? Is by USB or is it over the network?
adam watson
Berkshire, UK
Thats the first mention on the forum of an operational 5620 for ages :)
Sorry, have to leave this to the DB experts.
hairybadger
Bricoleur
46.1N 6.4E
see sig
note: I have no experience with either the Dreambox or the Raspberry.
but: samba keeps its logs in something like /var/log/samba . Check for this on the Raspberry. Can you ping the raspberry from the dreambox? Presumably the dreambox has a samba client. Can you run smbclient -L address_of_raspberry from it?
Just for info - what name is the drive known as to the Pi?
adam watson
Berkshire, UK
:D £18.50 on eBay so I couldn't resist. Pli are still releasing daily builds of images
adam watson
Berkshire, UK
note: I have no experience with either the Dreambox or the Raspberry.but: samba keeps its logs in something like /var/log/samba . Check for this on the Raspberry. Can you ping the raspberry from the dreambox? Presumably the dreambox has a samba client. Can you run smbclient -L address_of_raspberry from it?
I can ping from box to pi and pi to box. I'll try smbclient and report back. The drive seems to be sda1 to the pi
hairybadger
Bricoleur
46.1N 6.4E
see sig
adam watson said:
I can ping from box to pi and pi to box. I'll try smbclient and report back. The drive seems to be sda1 to the pi Thanks
Comparing the results of that with
net view \\name_of_raspberry
could be useful.
