BISS on DM800SE
Djskutz
1.1m triax . technomate diseq motor, DM800hdPVR, 1.8m Channel master, technomate tm2000, ps3 DM800se, Samsung led 55inch Samrt tv, 42inch philips plamsa flatscreen tv
Co. Offaly. Ireland
Lads i know this might br off topic but can anyone tell me how to add biss keys to a dm800se
It was, so I moved it ................... :)
Djskutz
Co. Offaly. Ireland
No.
Skybox F3, yes: DM, no.
A bit of googling suggests the constant.cw & softcamkey files may well be your friend.
Ah, so I could have helped after all: Same same with F3 :D
Djskutz
Co. Offaly. Ireland
i tried to add keys to it and nothing is working
Djskutz
Co. Offaly. Ireland
Syntax is all: Did you type keys in manually or cut/paste or did you load a file from elsewhere?​
Djskutz
Co. Offaly. Ireland
copied and paste keys into first line of softcom.key in dcc runnin on cccam2.3.0
On the F3, after entering keys a reboot is required: Is it the same for DM?
Edit: I can't keep up!
Djskutz
Co. Offaly. Ireland
did all of the above and still nothing
Is it a 4:2:2 feed? Normal receivers wont decode the video on them. There are ways round it but its a faff
Djskutz
Co. Offaly. Ireland
not sure but ive tried it with other feeds and nothing, i know im doing something wrong, is there certain boxes that decrypt 4:2:2 feeds
Only the Azbox, IIRC.
And the Az is seriously out of date now!
Which feed is it - post the frequency, sr & satellite & someone might be able to have a look for you
(dont post the biss key - thats against the rules here)
