Where Is The Headphone Socket? (Goodmans LD2665D TV)
heavensent
1.2 meter dish
technomate box
I can move the dish manually if I
want to change sat
But since the change over to digi
I find it difficult to find satellites
(must be the digi delay )
N England
Im trying to help an old couple a few houses away.
They have a tv........
goodmans mod no LD 26650 its a small 24 "? LCD tv
I gave them a pair of headphones
I had a look on the set for the usual earphone socket
could nt see one.
There are lots of the other type of socket awkardly placed all facing downward.
I contacted goodmans by e mail they said they know nothing of this model
it was made under license for Comet.... go contact them.
Comet of course no longer exist !
pontiend
Contibruter
south yorkshire
I have a 24" logik LCD.Different brand but you never know.Lots of rebranding these days.There is a phones socket underneath at the side of the ariel socket.
I've given your plea for Help a somewhat more descriptive Title ;)
Any concealed flaps low down on the sides, or even on the front panel?
Further: Google has never heard of that Model either.
As it has 26 in the code, perhaps it's a 26" (That tends to be part of the manner of naming), or if it really is 24" then maybe you've noted the code down incorrectly?
Edit: Cracked it - It should be LD 2665D >> That exists! (Topic Title further amended)
Just checking links to see if it throws anything up.
pontiend
Contibruter
south yorkshire
It will be one of those small ones. Somewhere around 7 or 9 mill arn't they.
There are a reasonable number of links now we've corrected the Model No. plus even more for the newer LD2667D.
Still not found a decent set of piccies, though.
They don't call me Sherlock for nothing.
Actually, they don't call me Sherlock at all.
Even smaller: 3.5mm (Same a MP3 Players, Personal Stereo etc.)
Yes indeed: The only pics I could find (Of the newer Model) didn't show it clearly, but it seems a lot of the connections are under an overhanging shroud at the bottom edge of the rear panel.
But the main thing is that there is one - just a matter of homing in on the little swine!
sonnetpete
wordpress.com
Normandy, France
Don't know if this helps but this is listed as an image of the main circuit board for the aforementioned Goodmans model.
If I had to plump for one of the many connections along the bottom edge, I'd pick the one to the right of the tuner input. If a concensus agrees you can say it was elementary....
Yup that connector on the right of the bottom edge looks a very likely candidate.
