Retired human
- See signature
- North Somerset
I am probably talking out of my arse but can you not open the LNB housing and see what frequency crystals are?
The SL3 is effectively 3 lnbs in one case ..so I simply wasn't sure of the LO frequencies of the Left and right LOs accuracy and therefore the accuracy of the displayed scale by crazyscan after conversion by the SUP-2400.The LO reportedly (as Vipersan also noted in this thread) should be 18050 MHz.
19700...20200 MHz converts to 1650...2150 MHz
18300...18800 MHz converts to 250...750 MHz, or with the extra 2400 MHz mixer to 2150...1650 MHz. That means effectively a LO of 20450 MHz.
These LO's and ranges can simply be entered in Crazyscan here (after choosing Ka-band or Ka-band Inverto).
Maybe I missed the point, but what is the problem really, is the LO different?
Excellent list buddy ..I've bookmarked it for future reference,Check Lyngsat Astra 1L, 18359H and 18366V should still be active.
Also 18411 MHz should have a data carrier: http://forum.dxtv.de/wbb/thread.php?threadid=20931
Your "comet constellation" on 11787 MHz, I'm not sure what LO setting you were using there?
If it was 9750 MHz, then the IF was 2037 MHz, so 20450 - 2037 = 18413 MHz.
If for the time being, you would select "L-band" LNB in Crazyscan, calculations would be a little easier!
You may check my list for other Ka-band capable satellites:
http://members.ziggo.nl/hvdh16/Sats/Sats.htm
Yep ..nothing from Hylas other than data signals AOL etc...but they are mighty strong so should be easily receiveable.hi VS i have been having a go at ka got a inverto ka lnb tried 9E i knew i would not get the transponder for the irish channels but did a scan on the TM as you know the lo is 21200 if i put that in the receiver it scans between 22000 and 23000 and the scanned frequency was 22117R 25000,so i worked out that if you put in the lo at 19170 the scanned frequency worked out at 20188R 25000 its the same as the Saorsat signal but right hand,tried horizontal nothing,i also tried Hylas at 33.5W got 20385H 8332 both signals must be data.
