55E (Yamal 402)
adonis1
Feed !!! tagged as "RUS065"
12536H 4444 Auto
Reasonable reception from 11265V 30000 3/4 this morning - finally managed to get some video from the TRK Schyolkovo test.
This is on the Y-402 Russian beam
Nice. This is "Podmoskov'e" channel feed - channel for the Moscow region.
pride21
Sandown Isle of Wight
hi AS you are doing well on this sat cannot get a sniff on the Russian beam.
Clear skies only with this one - the merest hint of thick cloud or drizzle & its away
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
I just got this Freq on 55E with a 1.2 Dish.....12522 V 27500 8PSK 3/4 DVS-S2 (Northern Beam - LyngSat)
One channel is named HD Media 3D and the other is NTV0
Nice - no sign of that one here although 11265V is a bit stronger than this morning here atm.
12522V is on Northern beam, so it should be easier to get, AS... Though that frequency was very borderline on Penta 85 when it was up. Keep wanting to put a 1m dish up for the eastern skies but I get these channels elsewhere for the moment, so no real need yet!
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
11265 V is on the Russian beam. No chance for it down here.
Nothern beam - Im getting a weak signal off 12694V 15284 3/4, although it doesnt scan any channels as its a multi stream.
Zip off the other one 12674V 14940 3/4
EDIT - a very weak & intermittent lock on 12674V just appeared. Max 10% quality on the F3
Reasonable strength signals off 11265V here atm if anyone wants to have a go. The pic is ok as long as there isnt too much movement!
Weather is cold, very still and no cloud cover
Great signals off 55E atm - 11265V (same as in the screengrab above) is coming in at 55-60% :)
Still two trees to go ............................ Patience.
The signal disappeared as soon as the drizzle started :(
I would be really interested to know if the 11265V transponder can be received anywhere in Southern England... I know of one unsuccessful report in Kent on 1.2m dish, so it's not looking good.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
Got a signal off these two Freqs but when I check in 'New Services' I find no channels listed. Most probably streams.
Those 2 are multi streams & will require a pc card to view.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
Lyngsat reports some channels on the *southern* beam - 11045 V, SR 40000(!) 2/3. Can't "see" the satellite so can't check...
