Astra 2E: Testing at 43.5E
Hi M60, Could you give a hint which of the tested frequencies were previously on Astra 2b. Could thus be relevant for fringe reception areas (e.g. Cairo) where 2b provided SSp 1-3, itv1, c4 NI etc....
Hi Rickky, I've not got the actual frequencies to hand but do have the SES TP No's of the ones from 2B, migrated to 1N and 2A after 2B was moved off that I got from Lyngsat so, obviously, not 100% gospel but here goes:
TP19
TP20
TP21
TP23
TP24
TP25
TP26
TP27
TP28
TP29
TP30
TP31
TP32
TP34
I've just added all the listed test frequencies up to this point in the forum thread (from page 25) to the existing list on my spreadsheet, will post up late this afternoon with any more additions from here on. If testing does continue next week I'll add the rest when I return from my hols.
I have been trying to get SatSpectr_1090 to work on a TBS 8922 DVBS/S2 tuner, can not seem to get any signal even at 28.2 east.
It works fine with CrazyScan.
Is there a tutorial in English anywhere, or can anyone point me to a thread or tell me what settings I need to use?
12073h seems to be active right now with very weak signal in my location.
12056v is active right now
2E is still testing,this means the launch delays did not put SES in any hurry as it was previously suggested
Testing at 12582H and 12662V right now.
Are those TP's the only live ones at the mo?
As far as I can see, yes.
People like to assume all sorts of things on here (I'm guilty of that too), a bit like when people where saying SES wanted 1N urgently for 19E so it would be moving when 2F was launched without knowing the full facts. All part of the fun trying to figure things out I guess but I do wish sometimes guesses where not posted as facts.
I can't see why there would be any short-cuts to the testing for any reason at all. Not doing things properly was the main reason why the Proton failed and the delays occured. Having got their bird safely up there there is now no way anyone is going to shortcut any proceedures simply to beat a Christmas embargo or some other trivial thing. This £mutltimillion object is needed to work for another 15 years or more so a few weeks of delay are really so unimportant as to be meaningless. No-one is going to be too upset now - no one is missing out - the broadcasters are delivering their programmes and when everything is ready and checked and double checked it can be moved and start its operational life. Simples!
"" or some other trivial thing ""
Blown fuse???????????????????????:D
Ok folks, here's my list, up to date of this evening.
There's a few descrepancies of a few MHz on various TP's, I've included some, but not all as it's clear some were the same frequencies centred slightly differently on people's DVB Sat Cards.
If there's any more to add by next weekend I'll add them on Monday 18th.
10714H
10722V
10725V
10729V
10748V
10770H/V
10773H
10788V
10806H
10810V
10818V
10842V
10858H
10862H
10866V
10870V
10872V
10876V
10891H
10905V
10921H
10958V
10964V/H
10970V
10986H
10990H
11011V
11015V
11030V
11054H
11055H
11090V
11117V
11134V
11137V
11384H
11428V
11437V
11460H
11513V
11523H
11529V
11532H
11532V
11571V
11617H
11620H
11623H/V
11626H
11637H
11640H
11676H
11678H
11704H
11708H
11712H
11725H
11747V
11750H
11750V
11765H
11770H
11779V
11815H
11817V
11822V
11837H
11842H/V
11856V
11876H
11880V
11895V
11934V
11939V
11941V
11980V
12015V
12036H
12051V
12056V
12073H
12101V
12115H
12148H/V
12300H
12304H
12324V
12344H
12363V
12382H
12400V
12402V
12417V
12441V
12460H
12493H/V
12519H
12582H
12662V
If I remember rightly it was posted at some point that all the TPs could be on both UK or PE beams (obviously not at the same time) . Is that correct?
Sent from my GT-I9205 using Tapatalk
It has been mentioned a few times but not sure on the source. Certainly it seems from the tests that at least some of the transponders can be switched, if not all.
Yes, it seems this satellite is more versatile than 2F.
Now we have more questions after several weeks of tests than we had before Astra 2E start testing.And if it is to add one,to which we have been witnesses and actors at the same time, would be that I don't think that all frequencies which have been collated by @M60 were on Astra.SES do tests on whole band {10700Mhz-12750Mhz}, if we take into account the carriers tested so far, but we don't know if Eutelsat will quit the band of frequencies it has now.After so many weeks of tests, we are sure of one thing, and that we are not sure of anything when Astra 2E will be operational :)
But we don't exactly know what it is that we don't know!
Don't forget some of the frequencies may also be for the Middle East beam so the range for Europe may be somewhat narrower than M60's list suggests.
I have noticed from a quick glance at the list is that the current bands where 2F is transmitting in doesn't appear to have been tested quite so thoroughly. Not sure if that tells us much.
"There are known knowns; there are things we know that we know.
There are known unknowns; that is to say, there are things that we now know we don't know.
But there are also unknown unknowns – there are things we do not know we don't know."
Where is Donald Rumsfeld when you need him??
In theory - is it not possible that the same frequency could be used on lets say the middle east beam and the UK spot beam, since you wont be able to receive them both at the same time when operational?
