rtl and rtl down from hotbird 31.12.2013
two popular channel rtl and rtl 2 report screen
signal will be down from end of december
will be only astra 12226h
here poople with 1.20 m panic
Pietclock
125cm
SE Germany 50°N/11°E
yep, they've announced that back in September. The Swiss versions will be on 19.2 only.
C0re
Specialist contributor
Ede
VU+ Solo SE
Gelderland, The Netherlands
Cutting costs. I guess that 99% of all German speaking Swiss satellite viewers can reveive Astra 19.2 next to the Hotbird. It amazes me that the German version of the Swiss public broadcaster isn's receivable via Astra.
the signal 11391h very weak here with 4,5 meter
need maybe 6 meter to get it
on 12266h
here got lock also 4.5 m not all days
Agorima
80 cm dish pointed to Astra 19,2° east - Ferguson FK 8500 HD
San Cipirello, Sicily
Pietclock
125cm
Satellite direct-to-home is not very important in Switzerland, over 80% use cable tv. The transmissions via 13 E were mainly used as satellite feeds to cable head ends. Swiss public TV use 13°E because it is much cheaper than Astra 19.2°E . And for less than 20% of their viewers, they do not want to afford Astra. It is also directed to Swiss expats - Swiss TV allows the smart cards to be used in foreign countries as well, as long the card holder is Swiss.
Retired Mod
www.timo.me.uk
Indeed, I've got a card (although I'm not technically Swiss, sssh). As Hotbird has a wider beam it makes sense to use it.
What people watch from these channels over there?
the rtl swiss use cable and rtl 2
the problem we dont know if ard and zdf also will be move mid 2014
Agorima
I think ARD and ZDF will rather stay only on Astra or broadcasting other programs on Hotbird during the World Cup.
Pietclock
125cm
ARD are only there to broadcast to the German troops in Afghanistan. They already had left Hotbird, but came back after soldiers complained they couldnt watch down there. ZDF use Hotbird as a backup for the terrestrial network - similiar to the BBC on 27.5W. The stream is a direct copy from the DVB-T Mux.
the ard zdf here much popular to use german speaker
many people ask why zdf hd and ard hd not use also with hotbird ?
Well for ARD probably because they are only there for the German troops stationed in Afghanistan, so any other viewers are pretty much irrelevant.
Once the German troops withdraw ARD will probably disappear off 13E
now screen on tp 39 12421h close eins festical old tp from astra 1m it move 11053h on astra 1l
new tp 11053h much weker here
photo of eins plus astra 1m
12421h
Pietclock
125cm
The HD transmission on 12.422h was not "official", it was always labelled a test broadcast. einsfestival only launched its regular HD service on 5th December together with a few other channels of ARD stations. I thought 11.053H was on 2C, like the other new transponder 10.891H ?
