Thanks Llew ..VS, there's a 11707.5 MHz beacon too on 2E. Try 1107.5MHz.
..but then no guarantee the dongle is working ..
VS
As Pietclock has found, beacons with strong adjacent transponders may cause interference, I suppose they may overload the input of your receiver. The ideal would be finding a satellite (2E being the ideal) with little interference from other satellites in the vicinity.Thanks Llew ..
No luck so far ..but then no guarantee the dongle is working ..or indeed that I am pointing at 2E..
Do you know any similar frequency beacons on a sat currently in service I can test on ? (fully active)
I have the lnb line from the gibby split ..and a DC block in the split line to the dongles input ..
NFM selected ...but nothing found at the pont on the arc I'm pointing ...about 20 clicks East of Turksat..
I need to make sure I can get it working on a known sat before searching for a needle in the cosmic hay-stack
also ..are the beacons polarity dependant ?
rgds
VS
Still holding at 43.5.Sounds like FSK to me. Perhaps the data is carousel'd and as such the carrier tone indicates the beginning of the transmitted data, possibly info relating specifically to the satellite, it's NORAD ID and other things?
Llew, is the beacon for 2E still at 43.5 or have you seen any drift? Just wondering as per Solly's post if we could be beginning to see some sort of movement? I won't hold my breath though!!
