Advice Needed Swedish Microwave LNB info please
DishDick
Gran Canaria
Thinking about getting one of these (as a quattro) but would like further info on it. Has anyone seen reviews of the SMW LNBs? Thinking about getting one for Astra 2E, but at just under 800 euro I would like to do a bit of reading before taking the plunge.
hairybadger
Bricoleur
46.1N 6.4E
see sig
My understanding is that dish size trumps a high-end LNB most of the time. Are you already at the limits of dish practicality and think that a more sophisticated LNB will pull in the signal?
DishDick
Gran Canaria
Yes 2.7m at mo. Don´t have the funds, space or understanding neighbours for a bigger dish.
800 euros ? ?????
hairybadger
Bricoleur
46.1N 6.4E
see sig
I guess if you have a 2.7m already in place they'd better be fairly understanding.
DishDick
Gran Canaria
Yes CH, was quoted by SMW - 728.93 Euros, plus 36.00 delivery, then VAT on top!
DishDick
Gran Canaria
Its like marmite, some are ok with it some not, but hey no planning permission needed here ( as one of them found out when they called the old bill) and I have now been here long enough to have been here with my dish longer than quite a few of my neighbours.
Is it a 2.7 prime focus ?
DishDick
Gran Canaria
No this is my dish, offset,
hairybadger
Bricoleur
46.1N 6.4E
see sig
What have you been using as an LNB up until now? Is the LNB you want to buy intended for a dish of this size? There has to come a point when you say "It's becoming too difficult/expensive and my children can live without CBeebies" :) Or you take a different tack - VPN and IPlayer, for example.
If it is offset then the overall height is more than 2.7metres. You could try installing a 3.8m offset on its side, which would probably be no higher, and the neighbours wouldn't notice.
DishDick
Gran Canaria
Unfortunately it fails two of my criteria - price and lack of space (larger dish won´t fit where I have the current one.
hairybadger
Bricoleur
46.1N 6.4E
see sig
How long is the cable run and is it of sufficient quality?
You need a larg(er) hammer.
DishDick
Gran Canaria
Hairybadger, I have short runs of good quality cable. I get all the stations I want at the mo, even ch5 (except in cloudy weather). I am just looking to the future, just want to squeeze as much signal out as I can. I have tried every branded quattro LNB and many non branded. Integrated and C120 with various feed horns, before settling on my present setup. I was hoping to find out about the SMW AB LNBs just to see if their high price reflected a better build quality with less noise induced by the LNB. Unlike other units which I have happly gambled 20 - 100 pounds to try, this is a big gamble!
That SMW LNB combo is some weight - over 1.6Kg. Hope your dish can bear it :eek:
